Author Topic: 3 Amber's Surely Can't Be Good... Can It?!?  (Read 3655 times)
Offline maidlow19
  • Turn that Frown Upside Down...
« on: 17 November 2017, 01:50 »
Newbie Golf Mk4 Owner here so pls, be gentle...  :undecided:I'm 2 weeks in from buying my gorgeous 1.6L 2002 Petrol Mk4 an over the last few days I've had 3 Amber warning lights come on individually and at separate unrelated times and have all remained on ever since, none of them have flickered, flashed or stopped or gone off an would appreciate some constructive advice from anyone who may have experienced a similar problem as I haven't got a Scrooby nor do I fancy taking to a garage an being stung only to find out later I could of fixed it myself. The lights in question like I said there all Amber and in the order they came on was, the ABS light, then a circle with a car skidding in the middle, then the third was the engine management light, so if anyone's got any idea I'd really appreciate, THANX...
Regards,
maidlow19
Offline bgbazz
  • If it aint broke...I can fix it!
Re: 3 Amber's Surely Can't Be Good... Can It?!?
« Reply #1 on: 17 November 2017, 08:57 »
I'm not too sure if all Mk4s are the same but TDI comes up with some weird stuff at times. This might sound strange, but try it anyway...check that all external bulbs, including brake lights, are working 100% as they should. My ABS light comes on when a brake light bulb has blown. The EML can come on for any number of reasons, but the first thing I would do is disconnect the battery for about 30 mins...hook it back up and see what you get. I use that time to check everything under the bonnet...all fluid levels etc. In almost every case with mine, the battery trick has worked...only time it didn't, it was the brake light switch...see separate thread in this section.
Good luck.
Mk4 Golf TDI Estate 4Motion, remapped 1.9. Sweet runner = keeper. She is the 66th vehicle I've owned and hopefully, the last.
Offline itavaltalainen
« Reply #2 on: 18 November 2017, 09:50 »
The first thing I would do is scan the car for faults..... this will give you an idea why they are on.
If you can't tell from the fault protocol then post it here and we'll have a look.
Example:
Saturday,xx,March,20xx,xx:xx:xx:xxxxx
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.1.3.0 (x64)
Data version: 20170220 DS267.3
www.Ross-Tech.com
VIN: WAUZZZ8E43Axxxxx  License Plate:
Mileage: zzzzzkm-zzzzzmi   Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
          67 69 75 76 77
VIN: WAUZZZ8E43Axxxxx   Mileage: zzzzzkm-zzzzzmiles
Address 01: Engine        Labels: 038-906-019-AVF.lbl
   Part No: 038 906 019 JT
   Component: 1,9l R4 EDC 0000SG  1572
   Coding: 00003
   Shop #: WSC 01234
   VCID: 72EBDE7E3E966Axxxx-xxxx
   WAUZZZ8E43Axxxxx     AUZ6Z0B0xxxxxx
4 Faults Found:
17571 - Fuel Temp Sensor (G81)
            P1163 - 35-10 - Open or Short to Plus - Intermittent
18009 - Relay for Supply Voltage Terminal 30 (J317)
            P1601 - 35-00 - Implausible Signal
18008 - Power Supply Terminal 15
            P1600 - 35-00 - Voltage too Low
18061 - Please check DTC Memory of ABS Controller
            P1653 - 35-00 -
Readiness: 0 0 X X X
Address 03: ABS Brakes        Labels: 8E0-614-517.lbl
   Part No: 8E0 614 517 A
   Component: ABS/ESP allrad      1726
   Coding: 04255
   Shop #: WSC 01234
   VCID: 2643F22EC2DExxxxxx-xxxx
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
            35-00 -  -
Address 08: Auto HVAC        Labels: 8E0-820-043.lbl
   Part No: 8E0 820 043 H
   Component:   A4 Klimaautomat   1116
   Coding: 00000
   Shop #: WSC 01234
9 Faults Found:
00710 - Defroster Flap Positioning Motor (V107)
            41-10 - Blocked or No Voltage - Intermittent
01809 - Actuating Motor for Temperature Flap; Left (V158)
            41-00 - Blocked or No Voltage
01842 - Potentiometer/Actuator for Temperature Flap; Right (G221)
            30-10 - Open or Short to Plus - Intermittent
00716 - Air recirculation Flap Positioning Motor (V113)
00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
00819 - High Pressure Sensor (G65)
            07-10 - Signal too Low - Intermittent
00532 - Supply Voltage B+
            53-10 - Supply Voltage Too Low - Intermittent
01206 - Signal for Duration of Ignition Off Time
            27-00 - Implausible Signal
Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
   Part No: 8E0 907 279 E
   Component: int. Lastmodul  RDW 0305
   Coding: 00001
   Shop #: WSC 01234
   VCID: 3467186604022xxxx-xxxx
2 Faults Found:
01497 - Bulb for Blinkers; Front Right (M7)
            57-00 - Electric Circuit Failure
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655 B
   Component: Airbag 8.4EP        2000
   Coding: 0010602
   Shop #: WSC 01234 000 00000
   VCID: 3663226E427Exxxxx-xxxx
4 Faults Found:
00588 - Airbag Igniter; Driver Side (N95)
            001 - Upper Limit Exceeded - Intermittent - MIL ON
01044 - Control Module Incorrectly Coded
            000 -  -  - Intermittent
00591 - Seat Belt Switch; Driver (E24)
            002 - Lower Limit Exceeded - Intermittent
Address 16: Steering wheel        Labels: 8E0-953-549.lbl
   Part No: 8E0 953 549 F
   Component: Lenksáulenmodul     0308
   Coding: 00012
   Shop #: WSC 63351
   VCID: 3663226E127Exxxxx-xxxx
1 Fault Found:
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.lbl
   Part No: 8E0 920 950 J
   Component: KOMBI+WEGFAHRS. RB4 D35
   Coding: 01400
   Shop #: WSC 01234
   VCID: 306F1476F01A18xxxx-xxxx
   WAUZZZ8E43Axxxxxx     AUZ6Z0B0xxxxxx
7 Faults Found:
01039 - Coolant Temperature Sensor (G2)
            29-10 - Short to Ground - Intermittent
00779 - Outside Air Temp Sensor (G17)
00562 - Sensor for Oil Level/Temperature (G266)
            27-10 - Implausible Signal - Intermittent
01176 - Key
00668 - Supply Voltage Terminal 30
01314 - Engine Control Module
            49-10 - No Communications - Intermittent
Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
   Part No: 8E0 951 177
   Component: Innenraumueberw.   0604
   Coding: 00001
   Shop #: WSC 01234
   VCID: 6BD5C31A19BCxxxxx-xxxx
2 Faults Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
            43-00 - Closed
01462 - Anti-theft alarm ultra sonic Sensor (G209)
Address 46: Central Conv.        Labels: 8E0-959-433-MAX.clb
   Part No: 8E0 959 433 BC
   Component: Komfortgerát T3B    1110
   Coding: 07115
   Shop #: WSC 01234
   VCID: 73E5DB7A418Cxxxxxx-xxxx
   Subsystem 1 - Part No: 8E2959802B
   Component: Tõrsteuer.FS BRM 0002
   Subsystem 2 - Part No: 8E2959801B
   Component: Tõrsteuer.BF BRM 0002
   Subsystem 3 - Part No: 8E0959801A
   Component: Tõrsteuer.HL BRM 0002
   Subsystem 4 - Part No: 8E0959802A
   Component: Tõrsteuer.HR BRM 0002
15 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
01134 - Alarm Horn (H12)
            29-00 - Short to Ground
01370 - Alarm triggered by Interior Monitoring
            35-00 -  -
00962 - Alarm via. Tilt Sensor
            35-00 -  -
01368 - Alarm triggered by Luggage Compartment Switch
            35-00 -  -
01369 - Alarm triggered by Hood Switch
            35-00 -  -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
            35-00 -  -
00956 - Key 2
            35-10 -  -  - Intermittent
01331 - Door Control Module; Driver Side (J386)
01560 - Passenger Door
            61-10 - Won't De-Safe - Intermittent
01332 - Door Control Module; Passenger Side (J387)
01561 - Rear left door
01333 - Door Control Module; Rear Left (J388)
01562 - Rear right door
            61-00 - Won't De-Safe
01334 - Door Control Module; Rear Right (J389)
Address 56: Radio        Labels: 8E0-035-1xx-56.lbl
   Part No: 8E0 035 186
   Component: concert II  GRO    0008
   Coding: 01001
   Shop #: WSC 01234
   VCID: 64C7A826F462xxxxxx-xxxx
1 Fault Found:
00852 - Loudspeaker(s); Front
            36-10 - Open Circuit - Intermittent
End-------------------------(Elapsed Time: 05:54)--------------------------
Offline bgbazz
« Reply #3 on: 18 November 2017, 10:44 »
Apologies to the OP...I didn't realise you had the VCDS stuff. The obvious way to go.
