Author Topic: Boot lip protection recommendations  (Read 6092 times)
Offline Ibdrew
« on: 12 November 2017, 12:19 »
Hi can anyone recommend a boot lid protector,
I have a white gti and want to protect the boot lip from scratches whilst loading the grandkids pushchair,
Not sure of which type/colour protector to go for so anyone with pictures and or recommendations would be much appreciated.
Thanks
« Last Edit: 12 November 2017, 12:57 by Ibdrew »
Offline mkviken
Re: Boot lip protection recommendations
« Reply #1 on: 12 November 2017, 14:09 »
I have xpel full kit in the front end of my CSS
They do a rear bumper strip too
Best bet would be buy some 3m or simulate drom ebaynajd just fit it ourself
Make a template out of craft paper and cut the film and fit it yourself it’s very easy doing flat surfaces
I saw a golf R with the black rubber vW protector in the rear bumper and it wasn’t pretty
Golf GTI 7.5 230 white silver
Offline Hebegeebee
Picked up 03/Nov/2017 - GTi-P, White silver, 5dr., Manual with extras
Offline maxie
« Reply #3 on: 13 November 2017, 08:33 »
« Last Edit: 13 November 2017, 08:35 by maxie »
Offline Ibdrew
« Reply #4 on: 13 November 2017, 18:26 »
Thanks for the suggestions, think mkviken you are right and a black rubber/plastic would look ugly,
I like the idea of the clear film type but not sure if they cover the full bumper lip or just the top flat surface.
Offline gti_travels
« Reply #5 on: 13 November 2017, 19:48 »
I've got a clear VW protector on the back of mine.
http://www.vwmotorparts.com/accessories-c-37_93_134/genuine-vw-golf-mk7-rear-bumper-protection-film-p-383.html
Hebegeebee - Are these simple enough to install yourself (I guess just clean surface well and stick on?!) and, more importantly, can it be removed without destroying the paintwork?  Cheers
2017 5dr Indium Grey DSG GTI, 19" Santiago
Offline mkviken
« Reply #6 on: 13 November 2017, 20:13 »
There’s ones on eBay that are a plastic boot floor liner but with a flap which you drape over the bumper when you open the hatch. Looks like a good idea
Offline wantmygti
2017 GTi Clubsport arrived June 2017
2007 Shadow Blue GTi, sold on after 10 years ownership
Offline Hebegeebee
« Reply #8 on: 13 November 2017, 23:03 »
I don't have any pictures of my installation. If I remember it in the morning I'll take a photo.
The clear film covers the top and goes over the lip too down maybe about 10mm.
It's a 3M piece and requires a very clean bumper, there's an IPA wipe, a lubrication solution and a squeegee tool included. The sachet of solution is to be diluted and sprayed onto the bumper and the film to aid with positioning. Then use the squeegee to remove the fluid from underneath the film. In the current cold conditions I used a heat gun on its lowest setting to help get the film to stick in place. A hairdryer should also work. This helps speed up the process of getting it to stick in place.
As for removing it, why would you want to?
Offline SimonHunterBelfast
« Reply #9 on: 14 November 2017, 03:13 »
i used my local car wrap company, to do the 4 door sills and the boot, using clear 3M film. Great job, no air bubbles  :smiley:
