Author Topic: New Mk6 R owner.(not yet but soon)  (Read 4195 times)
Offline big-pete
« on: 07 November 2017, 04:24 »
hello all,
im looking at buying a mk6 R at some point in the future(as soon as my current car sells),
after driving both manual/dsg im 100% set on dsg.(3dr/non sunroof/ideally with cruise/nav) the rest is irrelevant as ill be doing some weight saving/ring prep.
are there any things i should be looking out for when buying one? any major issues/faults?
cheers
Pete
Offline barrym381
Re: New Mk6 R owner.(not yet but soon)
« Reply #1 on: 07 November 2017, 15:40 »
Have you looked at prices for a second hand mk7r as there's not much between them
Offline dubber36
« Reply #2 on: 10 November 2017, 16:41 »
But Mk7 .:R's are like dog poo. They get everywhere.
When was the last time you saw a Mk6 .:R? The Mk6 will command a much better resale value due to it's rarity and future classic status.
Finding one with a sunroof may take some doing, but cruise and nav are easily retro fitted.
Offline barrym381
« Reply #3 on: 11 November 2017, 01:38 »
I see 2 everyday a blue one and a black one  :wink: although I see ten times as many mk7 r so I see your point
Offline BobbyT
« Reply #4 on: 20 November 2017, 23:52 »
7R is a better car but the 6 is rarer
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #5 on: 21 November 2017, 09:13 »
Main thing to check is that the heldex is actually working.
Engines the same as edition 30 mk5 and has few weaknesses.
Water pump: Check coolent level is not at min as this may indicate pump leaking.
Air con: check works as if not serviced can cause compressor failure.
Current Garage:
35+ years of GTI ownership.
