Author Topic: Charging Galaxy s8+  (Read 4498 times)
Offline kane1210
Charging Galaxy s8+
« on: 06 November 2017, 19:44 »
Hey all!
So I'm trying to get a decent charge from my 12v socket and also the usb in the dash and as any samsung owners will know the phone informs you how long till a full charge!
My current cable says over 6hrs till full charge! Shock!
Is my cable poor quality??
Get the same reading from the ish socket.
Offline Sequence
Re: Charging Galaxy s8+
« Reply #1 on: 06 November 2017, 19:48 »
Are you using an original Samsung cable or some cheap job? there is a big difference. also what car charger have you tried? you preferably want 2A+  im not sure what amperage the cars outputs.
Golf Mk7 R Lapiz Blue Manual
Gone, Golf MK7 2.0TDI GT Tungsten Silver
Offline I wanted a GTi
« Reply #2 on: 06 November 2017, 20:04 »
You could try something like this Quick Charge 3.0 Anker 42W 2-Port USB Car Charger PowerDrive+ 2 with Quick Charge 3.0/ Fast Charging for Galaxy S8 / S7, and Quick Charge 2.0, with PowerIQ for iPhone 7/ Plus/ 6s/ 6, iPad, LG G5, Nexus, HTC and More https://www.amazon.co.uk/dp/B01A4ZGLZ8/ref=cm_sw_r_cp_apa_B3laAbRNEHPBK
I loved having a 3 pin socket in my CC.
Offline fredgroves
« Reply #3 on: 07 November 2017, 09:07 »
I've never managed to get a fast charge from a car charger.
The best charger I have just about keeps the charge stable while I am using Wayez, listening to internet radio and the phone doing all of its other stuff.
If you are shocked by the 6hr charge time, its because you are used to charging it with the Samsung fast charger, which really is a fast charger for a very large battery. Everything else will suck by comparison.
Offline Vwjap
« Reply #4 on: 07 November 2017, 11:43 »
Doesn't the phone detect if it's connected to a pc or a charging point (plug socket), so if anything goes wrong it can't break the pc, pc is a lower charging of .5a whereas wall charger can be up to 2.1a, and some of the data leads charge slower,
Maybe get a dedicated charging lead? (If not using android auto)
Offline fredgroves
« Reply #5 on: 07 November 2017, 11:46 »
I'm using a cable that came with a Samsung fast charger.
It doesn't make my car charge my phone any quicker, nor does it make my laptop charge my phone any quicker.
It needs something capable of putting out the power needed for a fast charge... which means another sort of ciggy lighter adaptor of a sort I've never found.
« Reply #6 on: 07 November 2017, 12:55 »
Did you see the link I posted above?
Offline kane1210
« Reply #7 on: 07 November 2017, 18:10 »
Have purchased !!!
Thanks
Offline fredgroves
« Reply #8 on: 07 November 2017, 18:16 »
No, but i have now!
Thanks!
Shame I need my phone plugged into the damned socket in the cubbyhole for android auto tho...
Still, i can charge my other gadgets properly now!
Offline p3asa
« Reply #9 on: 07 November 2017, 21:21 »
You'll be sorted with the Anker. I got a similar one from them and like you my phone only really kept the charging rate stable. Whereas the Anker will fast charge the phone and run "Waze"  :rolleyes: with no problem.
You'll wonder how you survived without it.
