Author Topic: Scirocco engined mk1  (Read 6420 times)
Offline truff
« on: 21 April 2003, 16:34 »
Does anyone know how to fit a supercharged 1.8 engine to a mk1 golf i have heard its kinda easy bar sorting out the pipe work for the intercooler and i should use diesel drive shafts but can anyone give me a good guide please im currently stuck in a 1.1 i need this. :-/
« Last Edit: 01 January 1970, 01:00 by 1055631600 »
mo3000
Re: Scirocco engined mk1
« Reply #1 on: 23 April 2003, 20:10 »
Yeah its possible, but since yours is a 1.1 i wouldn't bother. You will have to change fuel tank, brakes suspension and engine loom & fuse box....... the list goes on.
 Much simpler to stick it in a Mk1 GTI as you will already have most of the above fitted to it. I have one for sale...... if your interested? ;)
Offline truff
« Reply #2 on: 24 April 2003, 20:29 »
cheers 4 that :)
wound you use the same engine mountings as the mk1 golfs
mo3000
« Reply #3 on: 24 April 2003, 21:21 »
Not too sure here without looking.
I know if your sticking just a normal scirocco engine in you use the golf GTI mounts from a MK1 but you say this engine is supercharged, Is this the G-lader supercharger fitted to Rallyes and G60 Corrados or some aftermarket special, (Rootes etc?) And is the donor scirroco a Mk1 or Mk2?
 If its a Mk1, use the Scirrocco's if not, you may have to bodge your own.
