Author Topic: I assume this is a multi speed fan ?  (Read 1066 times)
Offline 16vbanger
« on: 05 October 2005, 15:34 »
if it is what else needs changeing for it  to work properly ?
I have the loom from where it plugs in near the battery
and whats up with vw I keep finding better bit's on an 87 8v than on our 8816v  :shocked:
Oh I see the switch need's changeing  :sad: and I just flushed and refilled the cooling system yesterday and today I find I have two of these fans and senders  :angry:
« Last Edit: 05 October 2005, 15:39 by 16vbanger »
Offline takethefifth
Re: I assume this is a multi speed fan ?
« Reply #1 on: 05 October 2005, 15:48 »
wow multi speed fan!! wish i had one......  :cry:  (yes it is multispeed, rest i can't help with!)
Offline 16vbanger
« Reply #2 on: 05 October 2005, 15:50 »
it look's easy to fit since I have the plug in loom  :smiley:
check out 87 8valves for a fan and switch and loom since both 87s I've broke had the multi speed and not our 88 valver  :laugh:
« Reply #3 on: 05 October 2005, 18:31 »
to convert to a 3 speed fan, you need the radiator thermoswitch, the fan and the loom.  Follow the plug from the fan it goes to the thermoswitch then to a 2 pin plug, unplug it and swap it onto your 2 pin plug
Offline 16vbanger
« Reply #4 on: 05 October 2005, 18:37 »
as I suspected after looking a it properly Cheers mate  :smiley:
Offline 16vbanger
« Reply #5 on: 11 October 2005, 18:26 »
I assume the red and white extra wire is fused constant + ?
« Reply #6 on: 11 October 2005, 18:49 »
The red wire on the 2 pin plug is constant live, & the brown is live. The red/white wire is live when the thermoswitch on the rad opens IIRC
