Author Topic: Phone app to measure performance?!..  (Read 2326 times)
Offline Wide
« on: 21 October 2017, 08:05 »
Hello guys!
Is there an app that can measure the performance of the car, which is sufficiently precise as you do not need an external GPS puck.
Or are all these apps just worthless ?!
Want to test 100-200 with different tires sizes....
My Youtube Channel ** MK8 R and MK7.5 GTI PP**
https://www.youtube.com/channel/UCOQb17Kro9L-iuT91cKxsjA
And My INSTAGRAM FaceliftGT
https://www.instagram.com/p/CHKNpaNHog_/
Offline Vwjap
Re: Phone app to measure performance?!..
« Reply #1 on: 21 October 2017, 08:52 »
TBH GPS apps are all just the same, as I recall their all fine in a solid straight line but put a bend or undulating traffic and they can be a little out, plus it all depends on the polling
I prefer something like a rally computer/Taximeter that goes to the speed sense in the vehicle and has to be calibrated that way I'd know it's accurate
Offline scanesare
  • GTI Clubsport
« Reply #2 on: 21 October 2017, 09:19 »
It's not the app you should be worried about, the app just logs the data fed to it from the GPS module, if that data is accurate, then your times are also accurate. Standard GPS modules in smartphones are only 1Hz which equals to just 1 value per second (although they use some predictive algorithm to improve accuracy) and clearly for such use it's not accurate enough.
An easy thing you can do that offers much better accuracy is to buy an external GPS module like: http://gps.dualav.com/explore-by-product/xgps160/ that works at 10Hz and a lap timing app of your choice (RaceChrono Pro, Harry's Lap Timer etc.). It's a pretty accurate setup at a fraction of a cost of a p-box with much improved accuracy over a smartphone. I did that switch and then compared graphs of my driving at the track. In the smartphone log It seemed like I was zig-zaging everywhere and my speed values were weird. After I switched to XGPS160 + RaceChrono the telemetry looks much smoother and "normal". Total cost was around 110 eur for the GPS and then 5 or 8 eur for the Pro version of RaceChrono app which you can use to measure any acceleration you want (not just lap times).
In a sense, it's my own pretty accurate road dyno as I 've used it to compare different cars on the same piece of road or just trying to quantify the benefit of different modifications.
« Last Edit: 21 October 2017, 09:22 by scanesare »
Offline Wide
« Reply #3 on: 21 October 2017, 18:26 »
Thanks guys!, time to buy gps  :smiley:
