Author Topic: G60 flywheel VR6 clutch  (Read 5108 times)
Offline Brighouse-gti
« on: 11 October 2017, 11:57 »
So been having a butchers on the internet at this conv, but can only seem to find info on it which relates to the mk4 golf or the mk3 VR6 or the G60! Does any one know if this conversion works in the mk2 gti? Ive done the mk3 AGG 2.0l bottom end conv, and Im still using the standard box and PB head, from memory I think the box 020 ACD. Im thinking that the G60 flywheel should fit, its the VR6 clutch assembly Im unsure about. Can anyone help?
Offline Neo Badness
  • Feet are for pedals
Re: G60 flywheel VR6 clutch
« Reply #1 on: 12 October 2017, 21:29 »
Pretty sure g60/vr6 combo only works on 02a which is hydro (unless using Seat work around)
Your stock mk2 box, if that's what you're using is 020 so long story short a g60 flywheel /vr6 clutch won't fit unless you change to an 02a box.
Hth's
« Reply #2 on: 14 October 2017, 20:42 »
Cheers for the info, youve been a busy chap badness replying to all the Q's, your fingers must be tired from all that typing ;-)
