Author Topic: 52 1.8t AUM, hesitation, weird stutter after starting  (Read 3931 times)
Offline Manford
So I fixed the second air pump at the weekend and now when the car starts after couple of secs it kinda judders and then is fine
I’m also finding a hesitation/miss between 1500-2000 rpm. When under load at low rpm I get like a chirpy noise, I’m assuming I’ve got a leak somewhere?
I have no engine lights, no error codes via vcds.
Offline Manford
Re: 52 1.8t AUM, hesitation, weird stutter after starting
« Reply #1 on: 12 October 2017, 12:41 »
Update - Cleaned throttle body and maf.....seems much better now.
Still get weird noise / chirp when under load at low rpm.......
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 12 October 2017, 19:02 »
Would say it's an air leak somewhere mate, check all the pipes from the carbon canister right through to the ones going to the actuator
Offline Manford
« Reply #3 on: 17 October 2017, 16:27 »
I can hear the carbon canister clicking away...I thought it was going to be a leak somewhere was hoping for a quick way to find it, but do you think it's more likely on the bigger plastic stuff than the little vac lines?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 17 October 2017, 19:00 »
Unfortunately it could be anywhere, some splits won't show up until you move the pipes about
