Author Topic: Creaks from suspension / wheels  (Read 4029 times)
Offline st332
« on: 05 October 2017, 12:14 »
When I turn off the radio and A/C, I can hear various creaks from the car at crawl speeds when in traffic.
One creak seems to occur over bumps - suspension I assume.
Another seems to be related to the wheels; speeding up as I speed up.
Both sound like rubber/seals creaking, and don't seem to be coming from the doors/cockpit, though it's very hard to tell.
I've got a 7.5 GTI with <1000 km on the clock and DCC.
Is this normal?
« Last Edit: 05 October 2017, 12:30 by st332 »
Collected 20/09/17: Mk 7.5 GTI PP DSG 5dr Irish Spec
Extras: Dark Iron Blue Metallic, DCC, Alarm, Keyless, Park Assist, DAB Radio, Innovation Pack (Discover Media, High Beam Light Assist, Rear View Camera, Winter Pack)
Offline wantmygti
Re: Creaks from suspension / wheels
« Reply #1 on: 05 October 2017, 12:53 »
Guessing that some gummi pfleg on the doors seals may help.
2017 GTi Clubsport arrived June 2017
2007 Shadow Blue GTi, sold on after 10 years ownership
Offline Booth11
« Reply #2 on: 05 October 2017, 13:06 »
Best stuff I've found for feeding rubber door seals and window felts is VW Special Lubricant Krytox Oil, part no. G052172A1. Get it from TPS (not via website) approx £38 for 30ml but a little goes a long way, and applied properly it has very long lasting effect.  Imo, it's quite a lot better than gummi pflege, but either way, lubricating the seals which can dry out over time is one way to silence creaks/squeaks from seals.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Tara
« Reply #3 on: 05 October 2017, 13:14 »
I would give all a bit of advice when it comes to doors and forget about any lubrication as they don't last and just coveting up the problem , for 99.9% of the time all you need to do is torque open the door lock catch fitted to the body and just .move it slightly back and up a couple of mm and job done.
White GTI PP......
Offline Booth11
« Reply #4 on: 05 October 2017, 14:06 »
Depends on nature of problem - recent discussion on this on another forum. Krytox has served me very well for door creaks for last 2 cars.  One application in 3 years on previous car lasted beyond my ownership of the car.  Misaligned doors is a little different but adjusting via the door strikers can potentially be precision adjustment.
« Last Edit: 05 October 2017, 14:09 by Booth11 »
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline st332
« Reply #5 on: 05 October 2017, 16:23 »
I don't think the noise is coming from the doors, particularly the creak that seems to be happening with every revolution of the wheels.
Offline mcmaddy
« Reply #6 on: 05 October 2017, 17:18 »
Sounds like sticking driveshaft boots. Had this on my 2013 gtd, and dealer sorted it.
Offline st332
« Reply #7 on: 06 October 2017, 08:33 »
Thanks, might give the dealer a shout so
Offline corgi
« Reply #8 on: 06 October 2017, 15:04 »
I had a similar issue with my GTD 18 months ago... one front strut replaced under warranty as the strut top bearing was worn... and both rear dampers replaced under warranty at the same time as there was still a noise. No issues since.
Corgi
