Author Topic: Movie: Could not resist buying Semi Slicks for the GTI Facelift PP  (Read 3888 times)
Offline Wide
 After the first trackay, I felt I did not want to destroy my expensive and awsome Continental Sportcontact 6.
So after 6 months and 4000km with the car, I bought the 4th set of complete wheels for my wife's luck   :whistle:
I'm testing a featured Federal 595 RS-3, these will only be used for trackdays.
Therefore, I think they are good and do not go on even more expensive tires now ..
Will try these before winter, because soon the winter tires will be on ...
Much tire change  in the future ..  :grin:
https://youtu.be/w2EugCePMGw
« Last Edit: 03 October 2017, 19:01 by Wide »
My Youtube Channel ** MK8 R and MK7.5 GTI PP**
https://www.youtube.com/channel/UCOQb17Kro9L-iuT91cKxsjA
And My INSTAGRAM FaceliftGT
https://www.instagram.com/p/CHKNpaNHog_/
Offline I wanted a GTi
Be very careful using a track tyre on a track without uprating things like bushes because the extra grip of the tyres will pull the bushes to bits after a while.
Offline Wide
The Car is build for this, you can get semi slick Michelin from the factory now days ;)
But i know you could get problem with oilpressure, brakes and bushes on older cars with theses type of tires  :grin:
If you think so then that's fine, go for it.
Offline Wide
Stock from VW Pretoria with the Semi slick from the CS is the next step!, you should try!  :wink:
https://www.topspeed.com/cars/volkswagen/2016-volkswagen-golf-gti-clubsport-s-ar173178.html
Offline clubsport
Do you have adaptive suspension?
I would expect R grade tyres such as these to make the standard suspension feel quite soft on track once you get some heat into them.
See how it feels, upgraded springs may be your next modification to get the best from the tyres! :)
Offline Wide
I have DCC, i hope that is enought  :grin:. I donĀ“t what a to low car.. We have snow here  :wink: :sad:
Offline Wide
Someone else with Semi slicks?. I will try 235/45/17 , a little bit strange. But fast i hope..  :sad: :grin:
I think i need 10 more sub to my channel, what do you want to see people?!. I have some more movies to edit that will come soon..
Will have some driving on the ice on the sea soon!, that can be a little bit scary. But crazy fun.. :whistle: :grin:
