Author Topic: Movie: Trackday GTI PP Facelift!*Drone movie now!*  (Read 7101 times)
Offline Wide
« on: 19 September 2017, 19:29 »
So finally the first trackday was finalized.  :grin: :grin: :grin:
The car went above expectations and my new Cont 6 was extremely sticky when I lowered the air pressure really when they were hot ...
No incidents without burning in the front brakes after tire rubber stuck on the brake disc .. :).
Then I finally got up and talk a bit in video  ;)
Enjoy!
https://youtu.be/SukT53CwU_o
The Problem.. :grin:
https://youtu.be/eghevyO40Rk
Some red in the way.. :angry:
Drone movie! :)
https://youtu.be/GcQ2C3NK5mg
« Last Edit: 29 September 2017, 18:42 by Wide »
My Youtube Channel ** MK8 R and MK7.5 GTI PP**
https://www.youtube.com/channel/UCOQb17Kro9L-iuT91cKxsjA
And My INSTAGRAM FaceliftGT
https://www.instagram.com/p/CHKNpaNHog_/
Great vid!
Kind of reminds me of my journey to work!!  :laugh:
(obviously the latter is done in slow motion due to speed limits)  :nerd:
That looked like fun though, the car goes well and sounds really good too. :afro:
New tyres and brakes needed now?  :grin:
Offline Wide
Great vid!
 :grin: :grin:Thanks!,
Yes the car was great :) The Performance pack brakes had no isues. Pretty hard brake from 200 to around 60 every lap   :cry: :grin:
The day before it was the Swedish "BTCC" final at this track. So it ws much tire rubber on the track.. My tires look a little bit funny now, they have Slick rubber on them.....I hope it will disappear  :shocked:
But know the car is running in.. :grin:
It will soon be time for winter wheels for you I'd guess?
You can keep the now semi-slick Michelins for next summer  :grin:
Offline Wide
Noo 2 month more!, we don´t have polar bears either  :wink:
 :grin:It is no problem with my tires...a think... :sad:
Offline scanesare
  • GTI Clubsport
You should have pushed more! (joking of-course, you should only push as far as you feel comfortable) Your tires look ok, maybe a bit over-inflated for the track if what I see in the photos is extra wear at the middle, did you remove couple of psi before hot-lapping?
Mine look worse than yours after I experienced Sturup Raceway last Saturday and its super slow tight corners:
Offline fredgroves
You were doing pretty well there, especially with the weight of a passenger added.
Feel the Golf Powah!
BTW is your GoPro mount a shower curtain rail from Ikea?
Offline Wide
 :grin: :grin: I pushed like hell.......i think.. :sad:
Yes i think they are ok, but it is a lot of rubber from the track on them now....But hope it will go away   :grin:
Yours look like you had fun! ;). Clubsport?.. It was at Clubsport S on this trackday...It was fast... :wink:
I had 48PSI after the first stint!!, not good.. :angry:. Lowered to 40 PSI and it feelt great  :smiley:
Offline Wide
Thanks did my best with extra weight... :whistle: :grin:
Yes IKEA! is da sh***t.... Worked awsome!. Thanks for the tip on this forum..
Offline I wanted a GTi
Glad I could help, another tip is when you get into the car and have your seat in the best position, recline it a little and put your belt on, then pull it sharply to get it to lock into position and while keeping hold of the belt move your seat back back up to the on track seat position so that the belt is really tight. It helps to hold you in in your seat when you don't have a harness fitted.
