Author Topic: Speedo Changing Query  (Read 3343 times)
Offline Jordan_gti
« on: 19 September 2017, 11:38 »
Hi guys, Im thinking of changing my speedo in my MK4 Golf because when I bough mine there was a crack in the bottom right corner. What options do I have? Ive been reading up on it and Im getting confused between the IMMO 2 & 3 issue? I just want a decent set of clocks to put in. Also do I need to get them programmed in if I change them? cheers in advance, Jordan.
2002 Golf Gti 1.8T (AUM) LC9Z
Offline barrym381
Re: Speedo Changing Query
« Reply #1 on: 19 September 2017, 11:40 »
If it's the screen that's cracked why not just change that as any other set you stick in will need coded to your car
Offline Jordan_gti
« Reply #2 on: 19 September 2017, 12:13 »
Its the actual plastic screen that covers the speedo itself (as in the part that you could knock on lol) , can you change that?
Offline bgbazz
  • If it aint broke...I can fix it!
« Reply #3 on: 19 September 2017, 12:30 »
Yep!...straightforward swap over.
Mk4 Golf TDI Estate 4Motion, remapped 1.9. Sweet runner = keeper. She is the 66th vehicle I've owned and hopefully, the last.
Offline itavaltalainen
« Reply #4 on: 19 September 2017, 16:37 »
What speedo do you have now? Part number would help, otherwise photo and tell us where the immo light is (bottom right in rev counter or top of mph/km/h dial)?
Swapping them is easy, takes me only a few minutes. You can change just front screen but get the same make (i.e. Bosch/Motometer or VDO), it is also quite tricky to do. Easy to crack them when you remove.
