Author Topic: Silly question........apologies in advance  (Read 11297 times)
Offline Brenbo
Re: Silly question........apologies in advance
« Reply #20 on: 19 September 2017, 07:10 »
Funny really - my current and last Mk.7 were DSG but I have never used Autohold!
You can take your foot off the brake pedal when stoped if you use auto hold with DSG
You can do the same in the manual.
I Second that!  :wink:
Offline I wanted a GTi
« Reply #21 on: 19 September 2017, 08:49 »
Well yeah obviously but the point I was making was that VE changed it a few years ago. Before if you took your foot off the brake the the car would start moving, now it doesn't start until you touch the throttle.
Offline Jeni_R_
« Reply #22 on: 19 September 2017, 10:13 »
PANIC.............pulled into the car park at work nose first on a hill reversing into the space into reverse bite point and up on its hunkers it went ??? handbrake engaged  :huh: so takes out of gear tried again back into reverse bite point and no budge so i end up hitting the AUTO LOCK button to switch the whole thing off reversed and parked fine engaged (pulled up the teensy lever) the handbrake switched her off and left her in reverse as i am not petrified i go and find her embedded in the side of the balloon shop  :sad:
Am i being a total knob here and missing something ? i hadnt touched the handbrake at all i drove into the car park nose first on the hill tried to reverse and didnt budge  :embarrassed:
Offline fredgroves
« Reply #23 on: 19 September 2017, 11:55 »
Did you have your Seatbelt on? Germans love a bit of safety :D
Offline Watts
« Reply #24 on: 19 September 2017, 12:04 »
You shouldn't have to touch anything so something that shouldn't be is either on or off. Check your handbook and set up again from scratch. Once sorted as I've said, you won't need to touch it again in normal driving.
Previously:
Offline Brenbo
« Reply #25 on: 19 September 2017, 12:47 »
As Watts says, you should not have to touch anything when Auto Hold is on.  Even when reversing on a slope it should do all the hand brake stuff automatically.  I have a really steep slope on my Driveway.  Not once have I experienced anything like you describe. Auto Hold on my Golf works effortlessly on my driveway.  I have even forgotten how much of a chore using a manual handbrake lever could be when pulling away on a slope.
So as Watts says you may not have setup your Auto Hold/eBrake correctly?  I would check out the manual.
Offline Jeni_R_
« Reply #26 on: 19 September 2017, 13:05 »
aaaahhhhhhhhhhhh possibly not i cant remember i am in the habit of taking off when reversing  :rolleyes:
Offline Jeni_R_
« Reply #27 on: 19 September 2017, 13:07 »
I havent set it up as its a second hand car - is there a way to 'reset' things ?
Offline Watts
« Reply #28 on: 19 September 2017, 13:11 »
Not as such, you just need to ensure the autohold is switched on and the handbrake button is in the correct position. Best way is just a minute or two with the manual and set them correctly then job done!
Previously:
Offline mcmaddy
« Reply #29 on: 19 September 2017, 15:08 »
Can't ever remember it doing that to me in the Tiguan or Skoda superb with dsg. All it did when you took your foot of the pedal was start the car.
