Author Topic: Please help me identify coolant leaking part  (Read 2780 times)
Offline Saintkamy
« on: 17 September 2017, 07:02 »
Hi
My car started loosing all of the coolant as it reaches operational temperature. It suddenly just started today. I have located plastic part from where coolant is running down and steam coming out too.
Please help me identify what is this part by pictures.
Thanks in advance.
https://drive.google.com/file/d/0BzPyqHSTE98NZTRKMDdlaXQ2STA/view?usp=drivesdk
https://drive.google.com/file/d/0BzPyqHSTE98NUmZ2NVpFTWdaZVU/view?usp=drivesdk
https://drive.google.com/file/d/0BzPyqHSTE98NdHRHQVM3aW9kQU0/view?usp=drivesdk
Vag com codes are
VAG-COM Version: Release 409.1-S
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,16,15,17,19,22,35,46,56
Address 01: Engine
  Controller: 06A 906 033 AF
  Component: SIMOS33 1.6l 2V 00AT4083
  Coding: 00033
  Shop #: WSC 01271
  WVWZZZ1JZ2W481205     VWZ6Z0A3820669
2 Faults Found:
16706 - Engine Speed Sensor (G28): No Signal
           P0322 - 35-10 - - - Intermittent
17698 - Coolant Temp Sensor at Radiator Outlet (G83): Signal too Small
           P1290 - 35-00 - -
Readiness: 0010 0001
Address 02: Auto Trans
  Controller: 01M 927 733 JH
  Component: AG4 Getriebe 01M    4830
  Coding: 00000
  Shop #: WSC 00000
No fault code found.
Address 03: ABS Brakes
  Controller: 1C0 907 379 J
  Component: ABS FRONT MK60      0103
  Coding: 0001025
  Shop #: WSC 01271
1 Fault Found:
01314 - Engine Control Module
           013 - Check DTC Memory - Intermittent
Skipping Address 15-Airbags
Address 17: Instruments
  Controller: 1J0 920 806 C
  Component: KOMBI+WEGFAHRS. RB8 V17
  Coding: 03722
  Shop #: WSC 00000
Address 19: CAN Gateway
  Controller: 6N0 909 901
  Component: Gateway K<->CAN    0001
  Coding: 00006
  Shop #: WSC 01271
Address 46: Central Conv.
  Controller: 1C0 959 799
  Component: 1Z Komfortgerát HLO 0001
  Coding: 00259
  Shop #: WSC 01271
1 Fault Found:
00929 - Locking Module for Central Locking: Front Passenger Side (F221)
           27-00 - Implausible Signal
End   --------------------------------------------------------------------------------------------------
