Author Topic: Remove Kickdown with the DSG i manual mode?!  (Read 14563 times)
Offline Wide
« on: 14 September 2017, 09:51 »
This is the most annoying with the automatic box. I want to be able to stay at 2an and gas full without the car shifting completely hysterically to 1an.
Many who made a DSG flash to get rid of this feature in the manual mode?
This should also be done with the VCD or OBDEleven, anyone who dared it ?!  :whistle:
My Youtube Channel ** MK8 R and MK7.5 GTI PP**
https://www.youtube.com/channel/UCOQb17Kro9L-iuT91cKxsjA
And My INSTAGRAM FaceliftGT
https://www.instagram.com/p/CHKNpaNHog_/
Offline scanesare
  • GTI Clubsport
Re: Remove Kickdown with the DSG i manual mode?!
« Reply #1 on: 14 September 2017, 10:39 »
At least on the DSG6 in MK7 it is not possible to remove kick-down without a DSG flash. I can get 4th to 3rd or 2nd kickdowns from the box but 2nd to 1st it has never happened and it should not happen anyway. 1st is only for setting off and the box knows it, very weird if the DSG7 does that. I very rarely get automatic kick-downs anyway as I usually shift to the right gear myself without waiting for the box.
Offline clarky92
« Reply #2 on: 14 September 2017, 12:31 »
Do you mean with the dsg in manual mode (stick pushed to the left) your in 2nd , flooring it and the dsg in kicking down to 1st?
Offline CocoPops
« Reply #3 on: 14 September 2017, 13:22 »
Is there not a kickdown "notch" on the pedal travel? There certainly used to be, so you could go 100% of travel then push further to get kick down.
2018 GTI Performance Pack DSG 5dr, Tornado Red, Leather, 18" Seville Wheels, DCC Suspension, Tints, RVC
2018 Lotus Elise Sport220
Previous : 1983 Mk1 Golf 1.1 & 2008 Mk5 Golf GTI Ed30
Offline eatontrifles
« Reply #4 on: 14 September 2017, 14:26 »
Yes there is. It takes a reasonable effort to go past the notch and is noticeable, if you don't go past then the box stays in the selected gear.
Mk7.5 5dr GTI DSG. Isaac Blue, Keyless, Dynaudio, DLA & Lane Assist, DCC, Art Velours.
Offline Wide
« Reply #5 on: 14 September 2017, 15:38 »
Yes!  :angry:
Offline wantmygti
« Reply #6 on: 14 September 2017, 16:40 »
Yes!  :angry:
With the stick to the left, mine won't change up or down when driving, but it does shift to first if you stop without shifting down, but then won't shift back up through the box.
2017 GTi Clubsport arrived June 2017
2007 Shadow Blue GTi, sold on after 10 years ownership
Offline p3asa
« Reply #7 on: 14 September 2017, 17:09 »
It should change if you go to the limiter to protect itself and also if you are in to high a gear it should shift down.
Interesting from the comments above, mine will kick down without pressing all the way down to the limit switch.
Offline wantmygti
« Reply #8 on: 14 September 2017, 20:29 »
Yeah I haven't pushed it that hard as yet.
Offline clarky92
« Reply #9 on: 14 September 2017, 21:09 »
Yes!  :angry:
[/quote
When mine is in manual it will only shift down if the revs drop down too low eg coming to a stop and then auto shifting up at red line.
No kick down in manual mode in my 7.5 just been out to try it
