Author Topic: Big bumper slider bracket replacement  (Read 4802 times)
Offline shanemcb
« on: 11 September 2017, 21:00 »
I have to replace 2 big bumper slider brackets and was looking for advice on how it should be done. Part number of the brackets is 191 807 377A.Cheers.
Offline Neo Badness
  • Feet are for pedals
Re: Big bumper slider bracket replacement
« Reply #1 on: 13 October 2017, 23:34 »
It's pretty straightforward once you have the bumper off. If you look at the bracket you'll see two plastic pegs that are pressed into the bracket in the wing to expand and hold them tight. If you push them through with screwdriver or something suitable being careful not to loose them. You should be able to feel behind the wing and release the bracket. Refitting is as per Haynes; reversal of removal.
Should be pretty obvious when you have new bit side by side in front of you. Hth's
