Author Topic: 6-speed v 7-speed DSG  (Read 13443 times)
Offline mcmaddy
Re: 6-speed v 7-speed DSG
« Reply #20 on: 31 August 2017, 19:50 »
If it's the wet dsg 6 then isn't it the dq500? The dry 6dsg is the one that it is only rated upto 350nm. Mk7 gtd puts out anywhere from 350 to 380nm depending on what website you look at.
Offline I wanted a GTi
« Reply #21 on: 31 August 2017, 20:19 »
Does anybody have definitive information as to the final gearing between 6 & 7 speed DSG?
I'm interested if they are:
*  The same ratio in top i.e 7 speed has 1 more in the range to give closer ratios, or,
* A higher ratio for the 7 speed i.e. an overdrive ratio
Where's Daz Auto when you need him.
Ran out of petrol on the motorway.
Feck you Joe, I've just spit beer on my phone and the nice alcantara case I got for it yesterday so thanks.
Offline kalimon
  • My other car's a van
« Reply #22 on: 31 August 2017, 20:22 »
Probably in therapy : )
5 DR Mk 7 GTI PP
Offline Daz Auto
  • Other brands of washing powder are available.
« Reply #23 on: 01 September 2017, 00:10 »
Wikipedia to the rescue -
https://en.wikipedia.org/wiki/Direct-shift_gearbox
DQ200 7speed 250Nm Dry
DQ250 6speed 400Nm Wet
DQ381 7speed 420-430Nm Wet
As for the ratios I only have information from a user on Audi forum about the facelift S3. He did a graph showing that gears 1-6 are slightly shorter and gear 7 is longer and acts like an overdrive.
Someone recently pointed out to me that VW uses different ratios with different engines. They posted a link to prove it.
10/8/2017 - GTI Performance, Red,5dr DS
Offline JoeGTI
« Reply #24 on: 01 September 2017, 00:13 »
 :grin:
Offline mcmaddy
« Reply #25 on: 01 September 2017, 07:47 »
It was the dq500 box that was in the Tiguan I had. Quite a discussion on the Tiguan owners forum about it as dealers didn't have a clue  :grin:
Offline Wide
« Reply #26 on: 01 September 2017, 07:51 »
Interesting about the Ratio! I think my first gear is "shorter"  the DQ251, so it seems right!  :smiley:
My Youtube Channel ** MK8 R and MK7.5 GTI PP**
https://www.youtube.com/channel/UCOQb17Kro9L-iuT91cKxsjA
And My INSTAGRAM FaceliftGT
https://www.instagram.com/p/CHKNpaNHog_/
Offline Daz Auto
« Reply #27 on: 02 September 2017, 00:11 »
I have 1700rpm when 100kph..  :smiley:. Some help?
I checked today - at a level 60mpg the rpm was just over the 1500rpm mark. I would estimate it was 1600rpm.
Offline Wide
« Reply #28 on: 02 September 2017, 08:02 »
We should have the same?!  :sad: :grin:.. Or i woud have lower Rpm due to my bigger wheels  :smiley:
i will check with GPS the speed, and the obdelven the Rpm.. :wink:
« Reply #29 on: 02 September 2017, 09:02 »
If you have bigger wheels then you should have lower profile tyres which will have the same radius as 18" tyres.
