Author Topic: Tire pressure on 19" road and track?!?  (Read 4432 times)
Offline Wide
« on: 28 August 2017, 12:43 »
Yes, I know, you can read 1000 threads. But did not make any sense of this. :sad:
It is generally said that 0.5Bar will be added at Track. But because I drive 2.8bar on the street, I feel 3,3bar really crazy ?!
So what on the street and track?
2.8bar straight off on both ? :grin:
« Last Edit: 28 August 2017, 12:48 by Wide »
My Youtube Channel ** MK8 R and MK7.5 GTI PP**
https://www.youtube.com/channel/UCOQb17Kro9L-iuT91cKxsjA
And My INSTAGRAM FaceliftGT
https://www.instagram.com/p/CHKNpaNHog_/
Offline I wanted a GTi
Re: Tire pressure on 19" road and track?!?
« Reply #1 on: 28 August 2017, 22:16 »
Reduce for track, about 5-7psi, not sure what that is in bar.
Edit, the reason you reduce is because the tyre will get a lot hotter during a track event and in doing so will increase the pressure.
« Last Edit: 28 August 2017, 22:18 by I wanted a GTi »
Offline Wide
« Reply #2 on: 29 August 2017, 05:44 »
Sorry you talk PSI over there  :wink:. Ok like 0,5b less in the tires then..
When i drove on the track for teen years ago, you had to put like 6psi more in the tire on the track..
But that has now changed i suppose.
I not Talk abot R tire now  :smiley:
« Reply #3 on: 29 August 2017, 05:53 »
I was reducing tyre pressure 10 years ago too. I have never heard of anyone putting extra pressure in tyres for track.
Offline Wide
« Reply #4 on: 29 August 2017, 06:16 »
Some people says that the roads tires are to week. That you have to have som more pressure not to ruin the tire..
But that might not be the case now.. :sad: :grin:
« Reply #5 on: 29 August 2017, 06:29 »
Well a track day is not going to have a good effect on road tyre and especially tyres that have 5mm or more thread on them. Ideally you would want to have a track focused tyre or a road tyre with around 3mm of thread depth.
Have you done many track days?
Offline Wide
« Reply #6 on: 29 August 2017, 07:38 »
My tires are brand new, so it gonna be perfect..  :grin:
Yes around ten, but have not thought so much about tires pressure  :wink:.
Offline LRWmotorsport
« Reply #7 on: 30 August 2017, 09:57 »
Run 0.5 bar differential front to rear (0.5 higher on the rear).
Start off with your 2.8 front, 3.3 rear note how much pressure has built up and how it feels  after the session and adjust starting pressure as necessary.
2015 BRSCC PGTI Championship 2nd #55
2016 BRSCC PGTI Championship 2nd (again) #25 & BARC Intermarque
2017 BRSCC PGTI CHAMPIONS #24
« Reply #8 on: 30 August 2017, 09:59 »
If you cant kill the inevitable understeer and as you gain confidence increase F -R  pressure difference.
Offline Wide
« Reply #9 on: 30 August 2017, 20:03 »
Ok, interesting! :smiley:
Thanks
