Author Topic: What brakes to buy. Help needed  (Read 5476 times)
Offline Rob36mfc
« on: 22 August 2017, 22:45 »
I have a 97 2.0gti 8v Agg engine, I need new discs and pads all round but when i put my reg in online I get several different size discs.  I was then told if i have a 16" space saver my front discs will be 288mm , Is this correct ?  Any help.appreciated thanks
Offline itavaltalainen
Re: What brakes to buy. Help needed
« Reply #1 on: 23 August 2017, 14:42 »
Look at PR codes.... or measure them.
Offline gasketface
« Reply #2 on: 23 August 2017, 19:23 »
Your fronts will be 288mm.Rears are all the same on gti 5 studs.You will also need rear wheel bearings and probably rear abs rings if they don't come with them already fitted.
Your front calipers will have ATE cast in them.
