Author Topic: Play in front disc pads  (Read 3032 times)
Offline Marky153
« on: 13 August 2017, 19:28 »
Hi
My brakes clunk when going into reverse or when going forward.
Now they make a clunking noise when going over potholes.
Please look at video https://youtu.be/B4DO__U3BQg is this normal?
Regards
Mark
Offline I wanted a GTi
Re: Play in front disc pads
« Reply #1 on: 13 August 2017, 19:38 »
It's 2017 :whistle:
Hope you stay around when you get some help with your question! From what I can tell from the portrait video is that it has aftermarket or wrong sized pads fitted.
Offline CHB100
« Reply #2 on: 13 August 2017, 22:49 »
Hi
Regards
Mark
And you've only just noticed? I thought Arthur Daly had gone out of business.
Arrived 15/5/17 Mk 7.5 R Lapiz 5dr DSG, Prets, Pan Roof, DCC, Rear View Cam.
Our other car is a Mk7 GTI DSG 5dr Tungsten, Vienna, Rear View Cam, Park assist.
Offline Marky153
« Reply #3 on: 13 August 2017, 22:56 »
Hi
I have only just purchased car.
Offline itavaltalainen
« Reply #4 on: 14 August 2017, 13:06 »
Take back to dealer.
And by take back I mean have them tow it.
Offline 2007GTI
« Reply #5 on: 14 August 2017, 13:31 »
Offline kalimon
  • My other car's a van
« Reply #6 on: 14 August 2017, 13:53 »
What a warm welcome to forum you've had #Marky153  :embarrassed:
I'm sure you're delighted with all the helpful comments that have been posted :sad:
5 DR Mk 7 GTI PP
Online JoeGTI
« Reply #7 on: 14 August 2017, 14:14 »
Marky,
I've had this problem in my R for the last few months, but not to the extent that you seem to have it. The dealers had my car in to fix other things (which involved removing the wheel, greasing the pads, etc) and ever since that I get a slight clunk when reversing into my drive. I believe it is the front passenger side brake pad moving slightly in the calliper as the car changes direction. I'm told its quite common - and even normal to some degree.
But I will be asking them to look at it in the service which is due soon. Maybe my pads need replacing or some other adjustment is needed.
Offline skippy
« Reply #8 on: 14 August 2017, 14:16 »
Back in the day I owned an Astra GTE and I recall clearly the brake pads used to 'clunk' while reversing. Initially I thought I had hit something. That was caused by aftermarket pads as has been mentioned already, (not fitted myself I would add).
MK7.5 2020, Isaac Blue, standard spec
Gone but certainly not forgotten Candy White Scirocco 2.0 TSI
« Reply #9 on: 15 August 2017, 07:42 »
Vertical Video Syndrome!!
https://www.youtube.com/watch?v=Bt9zSfinwFA
That is so funny, and unfortunately too true.
