Author Topic: G60 / VR6 Clutch upgrade  (Read 4161 times)
Offline D4VEY01
  • 1999 GTI 1.8T AGU BLACK
« on: 30 July 2017, 22:41 »
Hi not been on here for a while,
Looking to do this very soon, Got the kit and bolts.
Cars an AGU, Year 1999, 5 Speed.
Will I need to grind the bellhousing ?
Is the clutch slave cylinder and release bearing ARM the same ?
Thanks in advance for any help.
P.S ive read the HOW TO but no mention of this.
Dave
1999 : GTI : 1.8T : AGU : SPEC 1 R-TECH REMAP : BOSCH SUPER 4 : FORGE TIP : SILICONE TURBO HOSE KIT : 18" RS4 ALLOYS : -30MM ADJ SPAX SHOCKS/SPRINGS : FORGE 007P D/V (YELLOW) : MILLTEK CAT BACK RES 4MOTION : POWERFLEX DOG BONE BUSHES : PIPERCROSS FILTER : FORGE ACTUATOR (YELLOW) :
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: G60 / VR6 Clutch upgrade
« Reply #1 on: 31 July 2017, 18:41 »
No grinding needed, only parts that needed changing were the clutch parts, everything else stays as is
Offline OSR
« Reply #2 on: 01 August 2017, 22:28 »
Did mine recently and as said above it all just bolts on, hardest bit is getting the gearbox off in the first place!
Offline D4VEY01
« Reply #3 on: 11 August 2017, 21:46 »
Nice 1 for the replies,
Just checking before I commit to the job,
cheers
Dave
Offline naiman
« Reply #4 on: 23 October 2017, 12:28 »
hello, i want to do the same to my agu . Can u help me with the codes of the g60 and the  vr6 clutch
