Author Topic: overfuelling  (Read 7073 times)
Offline dubslug
overfuelling
« on: 17 July 2017, 10:57 »
hi all
ive got a problem with my pb engine 1.8 8v
bit of back ground info
car was off road several years
replaced old fuel for new
new fuel filter
under car fuel pump died replaced with working second hand one
internal lift pump died so replaced
since then when driving in first or second at low speeds the engine is hesitant and kangerooy <not a technical term lol>  when you put foot down it bogs clears and then drives well.
the car stinks of fuel too
i did cure this once when car was warmish by turning off anf then on again and was smooth through all gears but havent managed since, im thinking maybe blue sensor??
1992 pearl grey 8v
Offline lemski
  • 16v
Re: overfuelling
« Reply #1 on: 19 July 2017, 09:12 »
Blue temp sensor or earth. My mates 8v burnt out something in the ecu and it use to just dump fuel into the engine. Injectors were always open. Only realised one day when the airfilter actually had fuel coming out of it
Offline dubslug
Re: overfuelling
« Reply #2 on: 20 July 2017, 20:47 »
hi mate
dont suppose you know which earths i need to check please?
i will get sensor, from vw im guessing not pattern part?? vag costs 3x as much is it worth it?
1992 pearl grey 8v
Offline lemski
  • 16v
Re: overfuelling
« Reply #3 on: 25 July 2017, 18:04 »
Gearbox to chasses i believe from memory. Or myght be gearbox to battery. Sorry fpr late reply
Offline dubslug
Re: overfuelling
« Reply #4 on: 05 September 2017, 14:04 »
changed blue temp sender
still same thing, oddly only seems for first run after that its back to normal and running okay.
kangeroos all over the place first run
1992 pearl grey 8v
