Author Topic: Latest Map Update Problem  (Read 12919 times)
Offline JB GTI
« on: 14 July 2017, 11:58 »
I have been trying to update my Discover Nav maps and keep hitting a problem.
I have updated with no problem in the past but this time it doesn't make any difference how I download the updates either as one big file or separate smaller files when it comes to extracting back to the VW SD card it gets so far then says there is not enough room on the card ??
I have backed up then deleted all the older files from the original SD card and even reformatted the SD card and tried again but hit the same problem. Reformatting it obviously doesn't harm it in any way as for now I have just dropped the backed up older maps back on and it works fine.
Any ideas what I could be doing wrong ??
Thanks
Now Gone: 3dr GTI Carbon Grey Performance Pack Dynaudio
Discover Nav Park Assist Rear Camera
Picked Up: 15th March 2014
Now Gone 3dr Golf R Lapiz Blue, DSG, Dynaudio, 19" Pretoria's, Discover Nav, Keyless, Rear View Camera
Picked Up: 1st March 2015
Now Gone Too: Mk7.5 Golf GTi Performance 5dr Indium Grey DSG Dynaudio 19” Brescia Alloys Vienna Leather Keyless Entry/Start Panoramic Roof 90% Tints Park Assist Rear View Camera Voice Activation Dynamic Lane Assist/DLA
Offline mcmaddy
Re: Latest Map Update Problem
« Reply #1 on: 14 July 2017, 15:56 »
Sounds like you've downloaded the Nav Pro maps which are bigger than the discover maps. Check what you've downloaded to see if that's the issue.
Offline itavaltalainen
« Reply #2 on: 14 July 2017, 16:08 »
Yes think you have downloaded either the files for Discover Pro and have a Discover Media (MIB1 or 2), or downloaded Discover Media MIB2 and you have an MIB1.
Offline JB GTI
« Reply #3 on: 14 July 2017, 17:03 »
I have double checked and you could be on to something  :smug:
The files I downloaded when I selected MIB1 (which I have) from the model checker have the file name P67_N60S3MIBS2_EU_NT.7z001 to 007.
I am assuming the last part of the file refers to the gen type of the head unit you have I.e MIB1 or MIB2 so the website is wrong as it only gives you the MIB2 files when you select Golf R 2015 and click MIB1
Can't believe I am am the only one caught out by this ??
« Last Edit: 14 July 2017, 17:06 by JB GTI »
Offline douglaslad
« Reply #4 on: 14 July 2017, 17:26 »
I have a Discover Pro MIB2 and get the message not enough disk space on a 32GB sd card. Anyone know the correct card size I need?
Pure White Manual 3dr Clubsport.
Dynamic Chassis Control, Panoramic Sunroof, Dynaudio, Sat Nav Pro, Rear view Camera, Car Net, Standard Sport Seats, 18" Belvederes.
Offline GTI_Ant
« Reply #5 on: 14 July 2017, 19:28 »
I got this as well this time.  I reformatted the card and followed the instructions.  The install on the card was almost complete when it stopped and said there was no more room.  In my case there were only one or two files it couldn't load and from the filenames these looked like somewhere in Germany, so not bothered.  I'm using the card with no issues.  The card seems to be an 8GB card and the map update gets bigger each time they release one, so it could be more of an issue next time I guess.
GTi Clubsport DCC winter pack rear camera
Previous:
7.5R 3dr DSG DPB Prets Dynaudio
MK7 GTI PP Tungsten Silver Manual Nav Dynaudio Winter Pack Park Assist
Offline JB GTI
« Reply #6 on: 14 July 2017, 22:37 »
Update.... All done ✅ I downloaded the DiscoverCare program and initially it still said I didn't have enough space when it tried to back up the previous version so I backed up the old maps to another location and tried again and it's done it 🎉🍻👍
Offline mcmaddy
« Reply #7 on: 14 July 2017, 23:44 »
Something either wrong with your SD card or you have something else on it. 32gb is plenty big enough to update Pro maps. Try formatting card and see what size is free.
Offline Finglonga
« Reply #8 on: 15 July 2017, 22:38 »
Having the same issues, the old map data is 7.03gb the new data is 7.28gb. Says there is not enough room on card even though I am 100% sure they are the correct maps and I am doing it exactly the same way as I have always done.
Trying the Discover Care route now, fingers crossed...........tick tock, tick tock.
Offline douglaslad
« Reply #9 on: 15 July 2017, 22:54 »
Discoverd that the message "Not Enough Disk Space" referred to my PCs hard drive and not the 32gb SD card, deleted some files to free up disk space on pc hard drive and that solved the problem.
