Author Topic: P1297 - Intermittent  (Read 3760 times)
Offline Manford
« on: 10 July 2017, 09:28 »
Description from v.c.d.s - Pressure drop between turbo and throttle valve (check D.V)
Assuming that means the recirc valve could be playing up?
Offline OSR
Re: P1297 - Intermittent
« Reply #1 on: 11 July 2017, 19:02 »
Most people have had this code at some point - not necessarily the DV but generally associated with the vacuum system and hoses degrading over time etc. Worthwhile checking the whole system over - cheap and easy to sort any split hoses with some oil line or silicone hose off eBay (depending on application) whilst you're at it.
Offline Manford
« Reply #2 on: 12 July 2017, 09:11 »
Thats cool, I took same approach with the Wrx, cheaper, quicker and easier replacing the piping than looking for a pin prick hole.
Do you know what Id pipe I need?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 12 July 2017, 21:16 »
4mm will do you
