Author Topic: Locking issues  (Read 9461 times)
Offline paradisiac82
  • 2003 Golf MK4 GTTDI ARL (PD150)
Re: Locking issues
« Reply #10 on: 11 July 2017, 06:57 »
They are somewhat coded, but that is done easily. But you need to get colour code that works for your car (there are a lot of different versions out there!!).
I would try to resolder joints (basically doesn't cost you anything) before getting another one.
I found it and wiggled the cables and it then locked and armed the alarm from drivers side, but didn't disarm alarm when unlocking, had to do that from passenger side :/ didn't last long before it stopped working though. Will try to remove the module when I have more time
Offline Mr_Orange
Re: Locking issues
« Reply #11 on: 11 July 2017, 07:20 »
Deffo sounds like a hardware issue then. Should be an easy enough fix with a soldering iron. Good luck ;-)
Build thread clicky
Offline itavaltalainen
Re: Locking issues
« Reply #12 on: 11 July 2017, 16:42 »
Yep, resolder joints, also your door lock microswitch(es) may be gone.
Offline Mr_Orange
Re: Locking issues
« Reply #13 on: 12 July 2017, 10:41 »
What he said ;-)
Build thread clicky
