Author Topic: Locking issues  (Read 9460 times)
Offline paradisiac82
  • 2003 Golf MK4 GTTDI ARL (PD150)
Locking issues
« on: 06 July 2017, 11:54 »
Hi, I know this is a question about a leon but they are pretty much same as the golf and you guys are always helpful.
The key fob that came with my mk1 Leon has never worked, doesn't even flash with new batteries, so I ordered one off ebay which does flash but won't program. I have used vag com and it says only 1 key is set which I assume is the original, but it won't let me change it to 2 (free version). Does this need to be done or is there another way to sync the new fob?
Also to note, with the key it only locks/unlocks the drivers door from the drivers side and does not set the alarm. I have to use the button inside the drivers door to lock/unlock the other doors. However if I use the key in the passengers door it unlocks all the doors but only locks the passenger side (front and rear). There are errors in vag com for the door module which I will post later, so I go 2 other modules from leons but they have different part numbers even though they were off the same model. Having tried them they do different things like not working off the door buttons or not operating windows. Are the modules that different as I'm finding it really hard to find one with the same part number as mine.
Offline itavaltalainen
Re: Locking issues
« Reply #1 on: 06 July 2017, 12:29 »
Can you do an autoscan an post the resulting (complete!) text file on here?
I can then tell you what is happening with your car....
Re: Locking issues
« Reply #2 on: 06 July 2017, 13:05 »
My version is the free one so won't let me do a full scan but can give you a screenshot of the locking module fault codes
Re: Locking issues
« Reply #3 on: 06 July 2017, 13:17 »
VCDS lite will let you do an autoscan, but only if registered.
Check fault codes in 46 and copy/paste the text output to thread. Easier than screenshot.
Re: Locking issues
« Reply #4 on: 06 July 2017, 16:43 »
VAG-COM Version: Release 409.1-S
Control Module Part Number: 1J0 959 799 AH
  Component and/or Version: 8P Zentral-SG Komf. 0001
           Software Coding: 04099
            Work Shop Code: WSC 06441
           Additional Info: 1J0959802F  8P Tõrsteuerger. FS0002r
           Additional Info: 1J0959801G  8P Tõrsteuerger. BF0002r
           Additional Info: 1J4959811C  8P Tõrsteuerger. HL0002r
           Additional Info: 1J4959812C  8P Tõrsteuerger. HR0002r
5 Faults Found:
00953 - Interior Light Time limit
        25-10 - Unknown Switch Condition - Intermittent
01179 - Incorrect Key Programming
        35-00 - -
00943 - Heated Exterior Mirror: Driver Side (Z4)
        35-00 - -
00913 - Window Regulator Switch: Front Right Driver (E81)
        27-10 - Implausible Signal - Intermittent
00944 - Heated Exterior Mirror: Passenger Side (Z5)
        35-00 - -
Re: Locking issues
« Reply #5 on: 07 July 2017, 11:14 »
Try resoldering all joints on the PCB (not the SMD components, only the through hole ones).
The 00953 code is usually from broken solder spots.
Re: Locking issues
« Reply #6 on: 08 July 2017, 07:29 »
On the ccm or the door module?
Re: Locking issues
« Reply #7 on: 08 July 2017, 17:10 »
CCM
Re: Locking issues
« Reply #8 on: 08 July 2017, 23:58 »
CCM
Are these coded to the car or can I get one from scrappy to test?
Re: Locking issues
« Reply #9 on: 09 July 2017, 13:37 »
They are somewhat coded, but that is done easily. But you need to get colour code that works for your car (there are a lot of different versions out there!!).
I would try to resolder joints (basically doesn't cost you anything) before getting another one.
