Author Topic: Clocks not working  (Read 6848 times)
Offline mvb
Clocks not working
« on: 28 June 2017, 13:25 »
Hi Guys,
Right, i have a 1996 Avantgarde 2.0 and having problems with the clocks
Mileage counter does not tick over, speedometre and techometre isnt working corectly either.
I bought another set of used clocks and same issue with them. so now i'm lead to believe this is something to to with the connections (sf the purchase clocks are in good order as the seller said).
so my question is does any one know of this issue at all and what the problem could potentially be?
Regards
MVB
I Love My GTI
Offline itavaltalainen
Re: Clocks not working
« Reply #1 on: 28 June 2017, 18:12 »
Any of the control lights coming on when you turn the ignition on?
Which engine code is it?
Offline mvb
« Reply #2 on: 29 June 2017, 12:35 »
all the light come on. its a 2.0 not sure on the engine code tbh
I Love My GTI
« Reply #3 on: 29 June 2017, 17:05 »
Have you tried speedo test mode?
Perhaps a GND fault on gearbox speed senders.
Offline mvb
« Reply #4 on: 29 June 2017, 21:23 »
what is this speedo test mode.
would a fault be shown on VCDS for this issues
when you say GND fault whay those this mean?
I Love My GTI
« Reply #5 on: 30 June 2017, 18:55 »
Test mode: https://youtu.be/JtHiQv39OMU
Mk3 speedo is not diagnosable via OBD - it has no link to OBD socket whatsoever.
GND fault, i.e. Ground connection for senders is wonky, so sensor won't work.
Sometimes and a bit incorrectly people refer to GND as Earth....
Offline mvb
« Reply #6 on: 30 June 2017, 19:53 »
Cheers,
i'll have a look tomorrow if weather permits
I Love My GTI
