Author Topic: Advice on purchasing a GTI 6  (Read 3958 times)
Offline SecondHeartbeat
« on: 24 June 2017, 22:08 »
Hello - first time posting here o/
I'm planning on purchasing a GTI 6 at some point in the next 12 months and I will have a max budget of 11k to spend. Im really just looking for some advice on what I should be checking for when viewing one of these cars i.e. common faults, any parts that should have been replaced after x number of miles etc.
Ive never actually purchased a car myself before. Ive owned a MK4 Golf 1.6 and currently drive a MK5 Golf 1.6FSI, but my father did the hard work in finding these cars for me.
Ive considered the GTI 5 ed30, but Im being swayed by the nicer interior of the GTI 6 and my gut feeling is the maintance costs will be less (no idea if that is actually the case).
Im also kind of debating on whether or not to go for the DSG because Ive heard good things about them, but I worry that it will feel like a less involving driving experience.
 :smiley:
Offline SRGTD
Re: Advice on purchasing a GTI 6
« Reply #1 on: 27 June 2017, 07:39 »
Hi SecondHeartbeat. I haven't had a mk6 GTI (I did own a mk6 GTD) and I've been a member on the forum for some time so hopefully can give you some general pointers of what to look out for.
If your budget is £11k maximum, depending on condition and mileage, that would probably currently buy you a late 2009 to late 2010 GTI. With a mk6 GTI of that age, I'd say one of the most important things to be aware of is the timing chain tensioner issue; the tensioner on the 2.0 EA888 series engine in the mk6 Golf GTI is prone to failure and a 2009 - 2010 GTI would have been built with the original version of the tensioner fitted. If it does fail, then you're looking at potentially very expensive repairs. The tensioner was revised 2 or 3 times during the life of the mk6 Golf, so always check to see if the original tensioner has been replaced with the latest version; ask for evidence of this (invoices/receipts for work done) and if it hasn't been done, I'd suggest budgeting for getting it changed a.s.a.p. and use this as a negotiating point with the seller. There's a very useful 'sticky' at the top of this section of the forum (Timing Chain tensioner Failure List) that's worth reading.
I'd always favour a car in good condition with a comprehensive service history over one with a high spec in poor condition as most of the more desirable options can be retro-fitted. Also bear in mind that some GTI's that are approaching 8-9 years old may have been modified by previous owners, and depending on what the modifications are, can result in increased wear and strain on the engine and drivetrain. Other things to look out for or worth considering;
  • DSG gearbox; these need servicing every 40k, so ensure this has been done.
  • Diamond cut alloys; The 17" standard wheels on the GTI were powder coated, but many GTI's came with the optional diamond cut 18" Monday Shadow wheels. These are prone to white worm corrosion and a good diamond cut refurb will cost in the region of £80-90 +VAT per wheel.
  • Tyres; the rear tyres can wear excessively in a 'stepped', 'sawtooth' pattern on the inside edge (you can see and feel this). If they have, they'll be quite noisy and make a noise that's characteristic of worn wheel bearings.
  • Xenon headlamps; not many GTI's have these, as they were an expensive factory fit option. I had them on my GTD and they were very good, so a bonus if you find a car with these fitted. The ED35 had them as standard, but this model will be outside your budget.
  • Leather trim; this was an option - standard upholstery is red "Jackara" tartan. VW leather isn't the best quality and is prone to sagging and creasing, especially the right hand bolster on the driver's seat cushion. With the cloth seats, check the bolsters for excessive wear, especially the drivers seat right hand backrest bolster.
  • Radio/CD player, standard fit was the RCD310. On the early mk6's this was backlit in blue which looks a little odd when the rest of the switch gear has red backlighting and the instrumentation is backlit in white. Optional units were the RCD510 (6 CD player, with touchscreen) or RNS510 (as RCD510 but with sat nav). RCD510 / RNS510 can be easily retro-fitted.
  • Bluetooth; was an option. If not fitted, this can be retro-fitted.
  • LED tail lights; unless retro-fitted, a 2009-2010 GTI won't have these, but were a popular retro-fit by owners.
Good luck with your search. I hope you find the right car!
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline mwad gti
« Reply #2 on: 27 June 2017, 19:08 »
Fantastic advice 👍
2019 3 door manual GTi Performance in black
Bought 2 years ago as a 1 owner car, FVWSH and 10k miles
It’s a keeper
Offline SRGTD
« Reply #3 on: 27 June 2017, 21:08 »
Thanks. Try to contribute to the forum when I can, even though I no longer have a Golf.
It's a shame that the mk6 section of the forum is so quiet these days, so I like to do my bit to help to keep it active!
« Reply #4 on: 06 July 2017, 23:33 »
@SRGTD
Appreciate you taking the time to give me such detailed advice! I feel a whole lot more educated and I will certainly find this very useful in my search. Seriously, thanks a bunch :smiley: Absolute legend!
Offline SRGTD
« Reply #5 on: 09 July 2017, 08:51 »
Thanks Second Heartbeat for the kind words.
There are lots of GTI's out there, so to get a car that's right for you, be sure to look a few examples and not let your heart rule your head and just buy the first one you see.
Good luck!
