Author Topic: Infotainment system turned off!  (Read 14562 times)
Offline golfberg
« on: 24 June 2017, 13:53 »
I was wondering if anyone had a similar problem to me.  On the display between the rev counter and the speedo I keep getting a message "Infotainment system switched off."  And of course the infotainmnet screen is blank and I cannot turn it on with the knob.
It does not happen all the time - it seems when I come to the Car in a morning.  Later in the day the infotainment seems to work perfectly and the message disappears.
Had the happened to others?
Thanks,
The car is  a 2016 Golf GTD.
Offline I wanted a GTi
Re: Infotainment system turned off!
« Reply #1 on: 24 June 2017, 14:15 »
Thanks,
Will it not switch on if you press and hold the on/off button?
Offline fredgroves
« Reply #2 on: 24 June 2017, 14:54 »
You get that message on the MFD if the MFD is in a mode where its trying to display something from the MIB unit - Sat Nav, Phone, Media track playing etc.
Does the message go away after a few seconds?
If you leave the MFD on something like speed or fuel range etc, you won't get the message - not that the message is actually a problem
Offline golfberg
« Reply #3 on: 24 June 2017, 15:26 »
Thanks for the replies -  there is no response to the on/off knob on the left hand side of the infotainment large display.  I have only had the car a month, so not sure if I was not seeing something obvious. The strange thing is that I can park the car up in the day and it works perfectly when I return - no "infotainment switched off" message in the MFD and sat nav, CD and driving data all work perfectly.  Cheers,
Offline fredgroves
« Reply #4 on: 24 June 2017, 18:44 »
So basically the infotainment unit doesn't switch on at all?
Offline golfberg
« Reply #5 on: 24 June 2017, 19:03 »
Hi,  yes it does sometimes.  I can go to the car in the morning and I have message in the MFD saying infotainment system is switched off and main infotainment screen in the dash is blank.  I try and turn it on with left hand knob on the infotainment and  nothing happens.  I drive the car in the day and park up. When I return, sometimes, the infotainment main screen is alive and well when I start the car and I  can access all the functions of driving data, sat nav, etc.   Cheers,
Offline Watts
« Reply #6 on: 24 June 2017, 23:31 »
I've had the dead screen of doom, if you press and hold the on button for some time it may reboot (ie not just press but keep it down for 10+ seconds) worked for me :smiley: Otherwise I think you are destined for a dealer visit.
Previously:
Offline fredgroves
« Reply #7 on: 25 June 2017, 13:30 »
Basically you have a fault with the unit. Others have had faulty ones before but its not that common I'd say.
Take it in and they will probably swap it out.
Offline golfberg
« Reply #8 on: 25 June 2017, 17:27 »
Thanks for the advice.   I have tried the 10 second reset and it seemed to work, but the unit was working when I tried it.  I will see what happens when the car has been stood for a few hours or overnight.  Fingers crossed it did the trick.  Regards.
Offline maxie
« Reply #9 on: 26 June 2017, 11:01 »
hi, sorry about hijacking your thread for a moment. but with these new systems are you able to watch video from your phones? thanks.
