Author Topic: And another odd fault Mk7 GTI  (Read 3617 times)
Offline CHB100
« on: 20 June 2017, 13:24 »
Having  been a WEEK! at dealers flushing out contaminate coolant on collection car on reserve fuel so topped up car, info showing range 355, gauge bending the needle (almost) So 65 miles down the road still the same in display 355 and needle not budged
Also when CAR vehicle settings is open on the infotainment the tiny pump in R/H lower corner has a small triangle with ! in it. Never seen that before and my R doesn't have it. The dealer checked others and said they all have the little warning? triangle.
Anyone else had faulty petrol reading issues like this and do you have the small triangle next to pump in display? Many thanks CHB
« Last Edit: 20 June 2017, 13:48 by CHB100 »
Arrived 15/5/17 Mk 7.5 R Lapiz 5dr DSG, Prets, Pan Roof, DCC, Rear View Cam.
Our other car is a Mk7 GTI DSG 5dr Tungsten, Vienna, Rear View Cam, Park assist.
Offline Tuckerjuk
Re: And another odd fault Mk7 GTI
« Reply #1 on: 20 June 2017, 14:03 »
Wee triangle next to pump is to indicate what side the tank filler neck is at so you know what side to fill your car
Offline Talk-torque
« Reply #2 on: 20 June 2017, 14:29 »
The range indicator is very coarse and gives the range available if you continued to drive as you are at that instant. If you were driving quite steadily, or cruising at a constant speed, it is quite possible that your range has increased enough to compensate for your mileage done. Apologies if you knew all that and you have got a fault!
Roger.
Offline CHB100
« Reply #3 on: 20 June 2017, 15:28 »
Thanks, We'll see, I know it can go up but 65 miles and still 355 seems more GTD than GTI! but doesn't explain the needle not moving? My  F/L R doesn't have that wee triangle by the pump btw.
Offline Sootchucker
« Reply #4 on: 20 June 2017, 15:43 »
Albeit mine is a May 2016 GTD (so there may be differences due to firmware upgrades), but mine doesn't have the small triangle either ?
Offline ajmoir36
« Reply #5 on: 20 June 2017, 23:01 »
I assume the little warning triangle is the low fuel warning.
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
