Author Topic: AGU 187g/s with standard map  (Read 3070 times)
Offline Robo018
« on: 05 June 2017, 00:23 »
New to this so if I'm posting in the wrong place help me out.
After reading about airflow / bhp ratio I plugged my diagnostic machine In today and got 187.22g/s at 6050rpm. Am I correct dividing this by 0.80 for approx bhp?
I've done a few mods and hoped to have a reasonable power but this is more than I'd expected on standard mapping, maf and injectors. Oh it's a K03s fitted on 13psi(boost controller).
What blocks should I be looking at to make sure this reasonably safe untill I can get the mappi g done?
Thanks.
2001 TT BAM, welly cooler, 80mm TIP, DW 65 pump, chinafold ported, hybrid tfsi wheeled ported turbo, Poly bushed suspension, Adjustable rear arms, Bilstein B8 shocks, haldex valve on a switch, BBT actuator, catchcan etc etc etc(AUQ fitted while in process of 82.5mm piston large port build)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: AGU 187g/s with standard map
« Reply #1 on: 05 June 2017, 16:59 »
I would hazard a guess that your MAF is duff, there's no way a standard MAP will kick out that much power. Also by having a boost controller rather than the N75 you won't get the soft limp mode that would potentially save your engine from an overboost spike.
To put it in real terms I have approx 230bhp and my peak boost is around 22psi so your readings are way off
Offline Robo018
« Reply #2 on: 05 June 2017, 21:23 »
You could be right what do you think is the best way to check it? Overboost hasn't been a problem since I ported the hot side of the turbo after reading up on what prawn and big al had talked about with Bill from badger 5 on a site a while back. The turbo seems to pull strong right to the red line too which is good.
I have just swapped the sensor from one that seemed to be making the car run badly.
