Author Topic: Alarm keeps going off.  (Read 4947 times)
Offline Smeds
« on: 02 June 2017, 22:55 »
Hello
The alarm on my golf keeps going off and won't disable. Weird thing is that it's only a problem when the car is unlocked, as far as I'm aware it never goes off when locked.
Even starting the engine doesn't stop the alarm. After about 5-6 time of it sounding it stops on its own.
Not sure if it's related but the interior light also flash and make clicking noises. I'm wondering if it's the battery.
Any help will be very much appreciated.
Smeds
Offline lemski
  • 16v
Re: Alarm keeps going off.
« Reply #1 on: 03 June 2017, 10:38 »
Had a similar proplem with an s3. I noticed that the fob is dead and its not unlocking the passenger door. So it sets the alarm off. What i did was unlock passenger door and it seems to sort it out.
Offline Smeds
« Reply #2 on: 03 June 2017, 11:20 »
Hopefully it's that easy, will try the spare key and see how it goes.
« Last Edit: 03 June 2017, 11:42 by Smeds »
Offline itavaltalainen
« Reply #3 on: 04 June 2017, 10:10 »
Sounds like an issue on the ccm.
Get that scanned with VCDS, also check door lock measuring blocks.
Offline Smeds
« Reply #4 on: 04 June 2017, 10:32 »
Still happening, got it booked into the garage on Thursday so hopefully they can find something.
« Reply #5 on: 04 June 2017, 11:18 »
Where are you from?
Get someone with VCDS to scan, garage will do the same but charge you an awful lot more.
Offline Smeds
« Reply #6 on: 04 June 2017, 11:55 »
Gloucester, it's going in for some other work and they said they can take a look at the same time. Got a friend with VCDS and he's gonna try and see it too.
« Reply #7 on: 04 June 2017, 14:01 »
My guess is that CCM has cold solder spots that have cracked.
Interior light error message in CCM is a usual indicator for this (in bold below, ignore the heated mirror errors).
If that's the fault then resolder all major joints on the PCB.
Address 46: Central Conv.        Labels: 1J0-959-799.lbl
   Part No: 1J0 959 799 AH
   Component: 4U Zentral-SG Komf. 0001
   Coding: 04097
   Shop #: WSC 00028
   VCID: 040788A61422546298-4AE8
   Subsystem 1 - Part No: 1J2959802C
   Component: 4C Tõrsteuerger. FS0002r
   Subsystem 2 - Part No: 1J2959801D
   Component: 4C Tõrsteuerger. BF0002r
   Subsystem 3 - Part No: 1J4959811C
   Component: 4C Tõrsteuerger. HL0002r
   Subsystem 4 - Part No: 1J4959812C
   Component: 4C Tõrsteuerger. HR0002r
3 Faults Found:
00953 - Interior Light Time limit
            25-00 - Unknown Switch Condition
00943 - Heated Exterior Mirror; Driver Side (Z4)
            35-10 -  -  - Intermittent
00944 - Heated Exterior Mirror; Passenger Side (Z5)
Offline Smeds
« Reply #8 on: 04 June 2017, 20:30 »
Cheers that's great info. Will let you know how we get on.
Offline dTEA
  • back in an MK5
« Reply #9 on: 05 June 2017, 23:43 »
   Coding: 04097
   Shop #: WSC 00028
3 Faults Found:
that also tends to mean that one door won't always open and can change to which one as well. Interior light not working is a telltale sign too.
Edition 30 / T5 T32 Kombi
