Author Topic: Got into accident today question about door and doorcard compatibility  (Read 5612 times)
Offline WeekendMechanic
  • Golf MK3 GTD
Iv got into an accident and the two right doors are pretty bad If I buy two secondhand doors will my trim and electric windows clip and bolt into place if I get any mk3 doors mine is a 96?
Offline itavaltalainen
Yeah should do, but only if the donor car is the same, e.g. Vento or Variant doors won't fit. Try to get from 95 car or later. Might be able to leave most stuff in.....
  • Golf MK3 GTD
Thats a problem as golf mk3  95`s latter,  are a little rare where I live can you be more specific?
Thanks for your suggestion though
Offline lemski
  • 16v
Later door means less stuff to change over. Early doors with say wind up windows ypull have to chamge everything over pretty much. 95 onwards youll probally get away with just changing the doorcard...
  • Golf MK3 GTD
Ok thanks but are the cut out holes in the doors for my door cards all the same as on pre 95 golf mk3s I don't mind changing things over as long as everything  fits and I don't have to worry about modifying the door holes ?
Offline lemski
  • 16v
Id have though but i cant day for definate as ive had early mk3s and only had to fix later ones. I cant see vw changing that much. Just the later cars came with more things as standard.
If you go to a scrap yard you could always just lull a door card off and check.
