Author Topic: Dash cam wiring.  (Read 4313 times)
Offline A13XDB
Dash cam wiring.
« on: 25 May 2017, 18:07 »
Hope fully someone can help.
I have bought a dash cam and want to wire it straight into the fuse box behind the glove box.
The cable kit I have has a micro fuse connector so won't go into the 20A fuse holder for the cigarette lighter.
Which micro fuse position will provide power when the ignition is on and off when parked up.
Alex.
Previous
Alfa Romeo 146 Ti
Mercedes C230K (W202)
Mercedes C200K (CL203)
Mk4 R32
B6 Passat Estate SEL TDi 170 DSG
2014 Mk7 GTI PP DSG
2010 Mk6 Gt TDI 140 DSG
2019 Mk7.5 GTD DSG
Current
2019 Mk7.5 R Estate DSG
2012 Skoda Yeti SE Tdi 4x4
Offline hog_hedge
Re: Dash cam wiring.
« Reply #1 on: 25 May 2017, 18:52 »
I hardwired into fuse 37 as per this thread: http://www.golfmk7.com/forums/showthread.php?t=27217
 :smiley:
Offline A13XDB
« Reply #2 on: 26 May 2017, 12:54 »
Perfect thank you.
Alex
Previous
Alfa Romeo 146 Ti
Mk4 R32
2014 Mk7 GTI PP DSG
2019 Mk7.5 GTD DSG
Current
Offline Lee099721
« Reply #3 on: 31 May 2017, 18:05 »
Would anybody no if you change the fuse behind the fuse box so the ciggy lighter works without the ignition on .and I left the dash cam plugged into the ciggy lighter all the time would it effect the battery and possibly drain the battery. This is on a new 7:5 gti thanks lee
Offline eatontrifles
« Reply #4 on: 31 May 2017, 21:22 »
It would drain the battery, yes. You can get a device which monitors incoming voltage level from the vehicle battery and will shut off the power if it gets too low; https://www.amazon.co.uk/Power-BlackVue-Vehicle-Recording-System-x/dp/B00LN2BZL2/ref=pd_sbs_263_8?_encoding=UTF8&psc=1&refRID=X28TV7YTJ2SG1ZF7J95Q
Mk7.5 5dr GTI DSG. Isaac Blue, Keyless, Dynaudio, DLA & Lane Assist, DCC, Art Velours.
