Author Topic: WLAN not available  (Read 5276 times)
Offline Briggsy
WLAN not available
« on: 19 May 2017, 22:47 »
Anyone else had issues with the Discover Media system, I did at one point connect my phones hotspot to the wlan in the car.
However that was brief, now it constantly says "WLAN not available - another connection is in use", when trying to get car-net registered (yes I have my access code) it seems to think that a car stick is installed, which it certainly isnt.
Anyone else ever suffer this and is there a quick fix?
If not I'll be back to dealers already!
Offline Eriktheviking
Re: WLAN not available
« Reply #1 on: 19 May 2017, 23:51 »
Park the car outside your house and use your home WiFi?
Offline Briggsy
« Reply #2 on: 20 May 2017, 05:45 »
Well...
1. That's no good to me when I want to use car-net in the middle of the Dales
2. Doesn't matter if its phone hotspot or home wifi, whenever I select WLAN on the menu setup it says the connection isn't available due to another connection in use.
Offline fredgroves
« Reply #3 on: 20 May 2017, 09:46 »
Hold down the power button until the MIB unit reboots?
Offline Gulfstream11
« Reply #4 on: 20 May 2017, 10:11 »
I.T guru right there,, ^^^^
Previous rides..MKIV 1.8T   MKIV PD150  MK5 GTI MK5 edition30 now MK7 GTI PP
Offline Briggsy
« Reply #5 on: 20 May 2017, 16:06 »
Good ole restart technique! Unfortunately it failed. (I'd already tried)
Offline fredgroves
« Reply #6 on: 20 May 2017, 18:20 »
Go into the setup menu and do a factory reset on the bit that is causing the problem?
Offline Briggsy
« Reply #7 on: 20 May 2017, 19:18 »
Done that including a full reset.
Offline 09GTI
« Reply #8 on: 20 May 2017, 19:26 »
Mine is the same worked once that was it
Rubbish
2014 Mk 7 GTI 5 door , Discover Pro , Pan Roof , DSG , ACC, Xenons , Parking  Sensors  , Rear Tints, KESSY.
Offline Briggsy
« Reply #9 on: 20 May 2017, 20:37 »
Well, after hours yesterday with no avail and having not touched it since 8am this morning, just out of curiosity tried it again just now and all of a sudden WLAN is working again and I was able to register for CarNet finally.
Guess something in the system decided to reset itself.
