Author Topic: Refurbishment of sun damaged plastic trim.  (Read 15139 times)
Offline philstar
  • ...life is all about creating memories...
Re: Refurbishment of sun damaged plastic trim.
« Reply #10 on: 17 July 2018, 19:21 »
Hi all, finally managed to get a test done using stonechip, very impressed with the results! Two light coats and the part looks brand new with a very subtle relief. Will be interesting to see how it stands up to being washed and how it fades in the sun. Check out these images (ignore the fingerprint in the middle it takes longer to dry than you would expect!)
1988 Atlas Grey VW Golf Mk2 16V GTi [F748 FGT]
Rebuilt: fuel pump housing | suspension | gear linkage | aluminium radiator
Offline gazareth
« Reply #11 on: 01 September 2018, 10:34 »
Heat gun. Did mine over a year ago and still look as good as new
probably lasts a lot longer if the car is garaged and not out so much.
Offline Tomb118
« Reply #12 on: 08 October 2018, 11:33 »
Hi Phil, do you have any more photos of the car? my other half used to own it!
