Author Topic: Replacement brake discs  (Read 8250 times)
Offline spider62
Re: Replacement brake discs
« Reply #10 on: 13 May 2017, 20:04 »
Tarox disks look good but if you have a PP,the Clubsport S discs are a straight swap,lighter by 900g per disc and available for less. :smiley:
https://www.awesomegti.com/shop-by-brand/oem/genuine-mqb-340x30mm-clubsport-s-front-brake-discs-pair-5q0615301c/
GTI PP MK7,LSG,DCC,Winter Pack,Kenwood GNV-MIB1 + VCDS Mods
Offline EricM
« Reply #11 on: 13 May 2017, 21:24 »
Make sure you give them a coat of silver hammerite before you get them fitted, they'll start rusting after a couple of months otherwise.
Must get round to doing mine soon, rusty discs really let an otherwise spotless car down
Offline Sandtrap
« Reply #12 on: 13 May 2017, 23:21 »
2014 GTI Performance
2012 Golf R DSG
2010 GTD
2008 GTD
2007 GTI
Offline whogives
« Reply #13 on: 24 October 2017, 18:18 »
I have a question, I'm just about to change the Rear discs and Pads........... Mine car has the standard brake kit.
The disc's I've had come are ATE Rear Discs (These are vented)  The disc on the car are solid ....Will these fit ????
The pads are EBC Yellow stuff pads
Offline spider62
« Reply #14 on: 24 October 2017, 19:38 »
As I said in my earlier post, there are two different brake set ups. The GTI has solid rear discs and the GTI PP has vented rear discs, if you have a PP car then these discs will be ok but they will not fit between the calipers on a standard GTI.
Hope that helps.
Offline whogives
« Reply #15 on: 24 October 2017, 19:47 »
Hope that helps.
This is what I thought, I used my Reg Details on the website too :( . To be honest its not the only site that has said these were correct. I'm struggling to find the correct solid type .....  Any ideas ????
Thanks for you help
Offline whogives
« Reply #16 on: 24 October 2017, 19:56 »
      https://www.carparts4less.co.uk/brake-discs    I've found them at last .Again thanks for your help
