Author Topic: wiring again  (Read 5571 times)
Offline crazydog
wiring again
« on: 10 May 2017, 20:24 »
hi guys,i have taken a feed wire from the ignition stud on the relay panel,i need to get this single wire through to under bonnet side,i have searched for somewhere i could get it through,, no success,any ideas without taking to many panels off,alternatively is there an ignition fed source under the bonnet i could tap into. all ideas welcome,if neccesary even drilling hole somewhere.  cheers.
Offline lemski
  • 16v
Re: wiring again
« Reply #1 on: 11 May 2017, 08:23 »
Where the actual engine loom comes through driversside in the scuttle theres a panel. Its also pretty close to the fuse box
Offline crazydog
Re: wiring again
« Reply #2 on: 11 May 2017, 17:32 »
sorry mate searched all in that area drivers side can't see any panel or even the main loom.  cheers
Offline crazydog
Re: wiring again
« Reply #3 on: 11 May 2017, 20:11 »
is it behind the relays
Offline lemski
  • 16v
Re: wiring again
« Reply #4 on: 13 May 2017, 10:29 »
It is but you need to take the plastic scuttle out to see where the loom goes into
Offline crazydog
Re: wiring again
« Reply #5 on: 13 May 2017, 12:15 »
ok thanks i'll have another go at that tomorrow,it gives me more idea where to look  cheers
Offline crazydog
Re: wiring again
« Reply #6 on: 17 May 2017, 21:20 »
thanks for info finally got it sorted as re your advice. one thing this will sound stupid, but when i came to put the scittle back all was ok until last bit which was two small pieces of plastic trim one each end of scuttle,no prob when i got them out but i can't figure how they go back i've tried all ways and they dn't fit right nowhere near  cheers.
Offline lemski
  • 16v
Re: wiring again
« Reply #7 on: 18 May 2017, 08:13 »
Without seeing a picture i wouldnt know. Ive fitted loads back in but cant remember exactly what went where
Offline bgbazz
  • If it aint broke...I can fix it!
Re: wiring again
« Reply #8 on: 18 May 2017, 16:38 »
Any chance those bit should have gone in first, before the scuttle itself? My car is away at the moment or I would check for you.
Mk4 Golf TDI Estate 4Motion, remapped 1.9. Sweet runner = keeper. She is the 66th vehicle I've owned and hopefully, the last.
Offline crazydog
Re: wiring again
« Reply #9 on: 18 May 2017, 17:26 »
they must go in last as i took them out first before removing scuttle,just had another go still no luck,if i can see any one else outside i'll have a look at theirs cheers
