Author Topic: Pulling away very lumpy at low revs ?  (Read 4909 times)
Offline Golfgtimk3
« on: 04 May 2017, 16:59 »
Hello when slightly using the excellerator the car judders vigerasly if you give it a lot of gas it's ok !
I've had the distributor , fuel filter, plugs and cables , crankshaft sensor and coil pack replaced but still doing this ! I can't seem to find an answer 1min car was fine an then this happened .
Please can someone help .
I hope I've described the problem right .
Offline Golfgtimk3
Re: Pulling away very lumpy at low revs ?
« Reply #1 on: 04 May 2017, 17:02 »
Btw it's a mk3 golf gti 8v .
Offline lemski
  • 16v
« Reply #2 on: 05 May 2017, 07:48 »
Throttle position sensor.
Has it been scanned
Offline itavaltalainen
« Reply #3 on: 05 May 2017, 08:18 »
2E, ADY or AGG?
Offline Golfgtimk3
« Reply #4 on: 05 May 2017, 19:24 »
It's AGG
Offline Golfgtimk3
« Reply #5 on: 05 May 2017, 19:31 »
It hasn't been scanned, a cowboy garage  told me to disconnect battery an reset ecu so did that an made no difference . But will that mean all codes all gone ?
Iv not got much knowledge on cars btw .
When pulling away or at these low revs when the throttle is only slightly down the car really jerks around . It's really difficult to drive . "Just trying to explain what is happening .."
Offline gasketface
« Reply #6 on: 05 May 2017, 20:49 »
engine mount gone ????
« Reply #7 on: 07 May 2017, 17:38 »
TB potentiometer?
Scan for faults and measuring blocks too. I can do scan if you're near me.
