Author Topic: Rear Brake Disc Wear  (Read 7376 times)
Offline GtiDad
« on: 02 May 2017, 17:08 »
Just put my 2 year old Gti DSG in for its second service and been told the rear pads and discs are 90% worn! It's only done 11,844 miles since new. I'm not a heavy braker and no warning light is on. Anyone else had this issue with low mileage?
Offline juggler
Re: Rear Brake Disc Wear
« Reply #1 on: 02 May 2017, 19:16 »
If I'm honest the fronts always go first on all my previous cars? The rears normally need replacing as they seem to get scored/corroded....
1976 Mini 1275GT
1983 MK1 Fiesta XR2
1988 Escort RS Turbo
1996 MGF VVC
2001 E46 2.5 Conv
2002 Impreza WRX
2004 E46 M3
2012 500 Abarth
2013 Punto EVO Abarth Supersport
2016 MK7 GTI
Offline wigit
« Reply #2 on: 02 May 2017, 20:47 »
My wife's R had a similar issue with her R after 15k and less than two years old with fronts fine, ironically my R had less wear and had been tracked and done more miles
Offline fredgroves
« Reply #3 on: 02 May 2017, 20:56 »
Rear brakes are used by ACC (it only uses the rears) and I believe its also used for ESP...
The discs shouldn't be worn though, the only time they get seriously damaged is if the pads are down to the metal...
Offline wigit
« Reply #4 on: 02 May 2017, 20:57 »
ACC has been used about twice on my wife's as she does not know how to use it
Offline fredgroves
« Reply #5 on: 02 May 2017, 21:16 »
Just FYI I've not knackered my rear brakes in 60k and I use acc all the time
Offline GTI-J
« Reply #6 on: 02 May 2017, 21:23 »
Sounds a bit fishy IMO.
I'd get the dealer to show you the wear in person or at least see it on the service video most of them send out. After 25k I've one rear that's a bit scored but otherwise they are barely worn.
5DR GTI PP 7.5, Indium, ordered 28 April 17, delivered 1 Sept 17, 19" Brecias, DSG, Lane Assist Plus, Discover Pro, Dynaudio, Reverse cam, DCC, Climate screen, Art Velour seats, 90% tints.
GTI history: MK7 PP Reflex Silver, MK6 Carbon Grey; MK5 United Grey; MK4 Reflex Silver; MK3 Tornado Red; MK2 Atlas Grey
Offline GeoBog
« Reply #7 on: 02 May 2017, 21:49 »
This. Usually one goes through at least two sets of front pads before changing the rears.
The ACC uses all brakes not just rear. I have noticed the rear rotors on MK7s get scored quicker than in other cars. Not sure if the ebrake has anything to do with it or the stability control which uses the brakes on the rear to keep the car under control when going fast in a corner.
2020 VW T-Cross SEL
2020 Renault Megane RS Trophy 300
2012 Fiat 500 Twinair
2007 Renault Megane 2
The two most important days in your life are the day you are born and the day you find out why.
Offline I wanted a GTi
« Reply #8 on: 02 May 2017, 22:09 »
I recon they are saying that because your rear brake hubs are corroded and they think you will fall for the 'look sir your brakes are worn, you can see how they look' line. If they were 90% worn then surely you would be able to see it. Plus there might not be ware connectors on rear pads, mainly because the fronts always go first and that warning will make you check them or go to a garage to have them checked.
Online Watts
« Reply #9 on: 03 May 2017, 12:48 »
If you aren't confident enough to check for yourself then take it elsewhere for a second opinion. I'd be highly dubious though for reasons given already and if right would be concerned that the brakes were binding. My previous car which a friend now owns is now on 110k miles and has had nothing changed on the rear brakes and is only just on its second set of front pads but original discs. And it was not a motorway mile cruncher, mostly local town driving plus it's an auto so should be heavier on brake wear...
Previously:
