Author Topic: wiring  (Read 2908 times)
Offline crazydog
wiring
« on: 25 April 2017, 18:51 »
hi guys i need to connect to an ignition fed source for a project,any ideas on what or where would be the easiest or best to find.all ideas welcome.   cheers.
Offline itavaltalainen
Re: wiring
« Reply #1 on: 26 April 2017, 08:32 »
Why don't you use terminal 15 from the potential distributors in central electrics?
Install an inline fuse holder with appropriate fuse.
Offline crazydog
Re: wiring
« Reply #2 on: 26 April 2017, 13:11 »
ok thanks excuse my ignorance where is terminal 15 are we looking at the main fuse box
Offline Ajamesc
Re: wiring
« Reply #3 on: 26 April 2017, 18:45 »
Remove the trim above the pedals and there's a fuse bored at the bottom wear the relays are there's a few studs. One constant live ones ignition live
Offline bgbazz
  • If it aint broke...I can fix it!
Re: wiring
« Reply #4 on: 26 April 2017, 19:06 »
Best and safest way to go.  :smiley:
Mk4 Golf TDI Estate 4Motion, remapped 1.9. Sweet runner = keeper. She is the 66th vehicle I've owned and hopefully, the last.
Offline crazydog
Re: wiring
« Reply #5 on: 01 May 2017, 19:20 »
ok thanks no prob panel came off easy as sugested wired into stud from ign.just as a matter of interest when i tested fir the ign stud i found the opposite end one had no live feed direct or ign,the others apart from the one i used from ign where all permanetly live. thanks again.
