Author Topic: Mk6 GT TDI Fan Running  (Read 31424 times)
Offline A13XDB
« on: 25 April 2017, 13:25 »
Sorry to wade straight in with a question having just joined the forum.
I have a 2010 Mk6 GT TDI which is a fantastic car.
Since purchase, bought from new in 2010, it continues to run the cooling fan for around 10 to 15 minutes once parked up.
We have repeatedly spoken to the local dealer about this and they say it is the Cat cleaning.
The car is not a high mileage vehicle, 47000 since new.
Always put decent fuel in it, Shell or Shell V-Power and never supermarket fuel.
I would appreciate some advice on what may be happening.
Alex
Previous
Alfa Romeo 146 Ti
Mercedes C230K (W202)
Mercedes C200K (CL203)
Mk4 R32
B6 Passat Estate SEL TDi 170 DSG
2014 Mk7 GTI PP DSG
2010 Mk6 Gt TDI 140 DSG
2019 Mk7.5 GTD DSG
Current
2019 Mk7.5 R Estate DSG
2012 Skoda Yeti SE Tdi 4x4
Offline SRGTD
Re: Mk6 GT TDI Fan Running
« Reply #1 on: 25 April 2017, 14:04 »
It's probably the diesel particulate filter (DPF) in the process of going through an active regeneration cycle (not the Catalytic converter cleaning) at the point you switch off your engine. The regeneration burns off the soot deposits that have accumulated in the DPF.
More likely to happen frequently if you're doing mainly short journeys.
There's lots of nformation on DPF regeneration on this forum and on the internet. The post at the link below gives a useful overview;
http://www.golfgtiforum.co.uk/index.php?topic=259626.msg2387838#msg2387838
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline Rhyso
« Reply #2 on: 25 April 2017, 14:05 »
What sort of journeys do you do in the car??  Have you ever had the DPF / glow plug light come on?
If its only short journeys then yes the cooling fans staying on would be because the car has / is doing a regen
However it shouldn't be after every journey. Usually a sensor partially fails. However this normally causes the DPF NOT to regen and thus you get the engine / DPF lights coming on
Offline A13XDB
« Reply #3 on: 27 April 2017, 18:47 »
Thank you people.
It does only do short journeys in the main, note the mileage.
We bought it when the word was "buy diesel, it's the fuel of the future and the environment"
Alex
Previous
Alfa Romeo 146 Ti
Mk4 R32
2014 Mk7 GTI PP DSG
2019 Mk7.5 GTD DSG
Current
Offline Rhyso
« Reply #4 on: 28 April 2017, 07:50 »
I would suggest getting a bottle of Forte Diesel Treatment or Millers Fuel additive, pop that in a tank and take the car for a good run and mainly use 3rd / 4th at higher RPM's, up hills etc to get the car up to temperature and help burn off the soot in the DPF
Every car needs a bit of 'Italian tuning' once in a while  :wink:
Offline A13XDB
« Reply #5 on: 29 April 2017, 11:58 »
Thanks for the advice. Living East Anglia hills may be an issue.
Previous
Alfa Romeo 146 Ti
Mk4 R32
2014 Mk7 GTI PP DSG
2019 Mk7.5 GTD DSG
Current
Offline A13XDB
« Reply #6 on: 17 February 2019, 08:53 »
OK. The car has now completed 56000 miles.  9 years old, nearly, on a 60 plate.
Even with the occasional "Italian Tune" and fuel additive it runs the fans.
There are no error lights or faults.
The car gets the FULL VW treatment at a VW dealer when required.
VW say it's cleaning. I must say it more meticulous than my mother in law if that's the case.
The car runs spot on returning >50 to the gallon on a run.
In two minds to change to update technology in the car.
The car is used by her in doors and she likes the tech in my Mk7 GTI PP.
As you can imagine it is like new, minor scrape on one alloy.
Thoughts and comments appreciated.
Previous
Alfa Romeo 146 Ti
Mk4 R32
2014 Mk7 GTI PP DSG
2019 Mk7.5 GTD DSG
Current
