Author Topic: Led GTI style headlights  (Read 13056 times)
Offline SunnyGTI
« on: 23 April 2017, 00:23 »
Hi guys
I was looking into what options there are to get the later GTI style headlights with the LED DRLs
I have found this:
http://www.hzperformance.com/index.php/body-kits/vw/golf/mk6/vw-golf-mk6-projector-led-headlights-352.html
Has anyone bought these before? Any opinions would be greatly appreciated :)
Offline _Adam_
Re: Led GTI style headlights
« Reply #1 on: 23 April 2017, 11:29 »
Considered mk7 style? Not everyone's cup of tea but I love them
http://www.ebay.co.uk/itm/182397569637
Offline SunnyGTI
« Reply #2 on: 23 April 2017, 19:55 »
I think I have found the headlights I want..!!
Just need to find a place that sells these
Offline itavaltalainen
« Reply #3 on: 24 April 2017, 16:46 »
Don't fall out the chair when you see how much they are....
https://www.autolampen.nl/en/tags/golf6-xenon/
They are right hand traffic though I would guess. I would be careful when ordering them, make sure they have the 'e' mark, otherwise not roadworthy.
Offline jord91
« Reply #4 on: 24 April 2017, 21:47 »
these look great for £330 but what type of bulbs do they take and are they just plug in and play ?
i would be interested in getting for my gti to replace those standard halogen ones  :smug:
Offline david25
« Reply #5 on: 27 April 2017, 18:44 »
Looks like they are modelled on the MK7 R double DRL design.
Translation
These headlights fit in every wave 6 and have the following specifications: Bi Xenon lighting LED daytime running lights and LED city lights 70% more light 40% whiter light Full plug and play, no further adjustments
Xenarc as seen the pics on https://www.autolampen.nl/en/tags/golf6-xenon/ is Osram's HID bulb brand name, so I assume these units are true HID.
More pics and video (warning : disable sound) note moving indicators just like the MK7.5
https://www.xenonlamp.nl/osram-led-koplamp-golf-6
E-keurmerk en TUV gekeurd = I guess this means they have an E mark?
Coming in May!
« Last Edit: 27 April 2017, 18:49 by david25 »
Now = 2011 MK6 GTI - Reflex Silver
Past = 2006 MK5 GTI - Tornado Red and Solid Black
Offline david25
« Reply #6 on: 27 April 2017, 18:54 »
Better static video (note you can press a button(?) and switch from moving indicators to tradition flashing!
https://www.youtube.com/watch?v=t4OyV_BHdkQ
More importantly, at the end they claim no washers or levelers required, how is this possible?
Installation, what are the red wires for?
https://www.youtube.com/watch?v=RK3dXPp5Lmw
Comparison, the lhs/rhs dazzle cut would have to be changed for UK roads?
https://www.youtube.com/watch?v=alXi9nkQtFc
Nighttime
https://www.youtube.com/watch?v=6-YSNo0SbuY
« Last Edit: 27 April 2017, 19:07 by david25 »
Offline dubber36
« Reply #7 on: 27 April 2017, 20:41 »
Washers and leverlers are required when cars leave the factory with xenon lights. They are tested as part of the MOT and must be working. If they are not fitted, they cannot be tested. If the tester is happy with the beam pattern and colour of the lights, then he may pass them.
« Reply #8 on: 01 May 2017, 15:23 »
They are a requirement for Xenons with 35W, factory fitted or not! There is a limit on what light intensity requires them... for that reason Osram offer 25W ones for retrofit - they don't require auto levelling and washers.
I would assume if they have 'e' mark and it does not say they need AL/W they will be supplied with 25W Xenon burners (and were tested for use with these)....
These 25W are designed not to dazzle other road users (as much), however they will still need to be fitted to headlights that are meant to be used with Xenons, i.e. not Halogen headlights.
Offline david25
« Reply #9 on: 01 May 2017, 17:46 »
Thanks, I didnt know that!
