Author Topic: adaptive cruise control not working  (Read 3650 times)
Offline mossy69
  • 2014 Gtd carbon grey pro nav dyn audio keyless wp
« on: 20 April 2017, 20:10 »
hi this has happened to me twice now comes up on the center display as error acc took it back to the dealers 3 weeks they sorted it but it has come back on again this evening acc doest work ...is there a quick fix I can do myself as don't really want to go back to the dealers    cheers
2021 Gti moonstone grey 19 Adelaide HUD winter pack
2014 GTD carbon grey pro nav dyn audio keyless
Offline fredgroves
Re: adaptive cruise control not working
« Reply #1 on: 20 April 2017, 20:57 »
Does it error every time you start it? Ie from one day to the next? Immediately you turn the key?
Offline mossy69
« Reply #2 on: 20 April 2017, 21:08 »
no just when im driving very strange I know any ideas  cheers
Offline fredgroves
« Reply #3 on: 20 April 2017, 21:23 »
Is it when you turn acc on? Again, immediately or just randomly? Does it happen in particular places?
Offline mossy69
« Reply #4 on: 20 April 2017, 21:57 »
no not really just comes on you have any ideas
Offline fredgroves
« Reply #5 on: 20 April 2017, 22:16 »
Sounds like it's maybe a loose connection or fault in the radar unit. Either that or alignment of the radar unit. It's a very precise alignment. You haven't hit anything at all? Rabbit or pheasant or something?
Offline Don76
« Reply #6 on: 20 April 2017, 23:37 »
Sorry for thread hijack, but how does lowering your car affect ACC??
OP - if I were you I'd get back to the dealer.
Offline Bungleaio
« Reply #7 on: 21 April 2017, 08:42 »
The sensor knows where it is relative to the road, within a tolerance to allow for natural movement and bumps in the road.
If you lower the car the sensor isn't where it thinks it is so it could give false readings hence why it should be recalibrated. Quite a few have lowered without it causing an issue but it can cause problems.
Abarth 595 Turismo + Classic Mini + Triumph Street Triple RS
Did have 3door DBP GTI PP
Offline fredgroves
« Reply #8 on: 21 April 2017, 09:18 »
I was told that fitting a tow bar could need it recalibrating too
Offline JoeGTI
« Reply #9 on: 21 April 2017, 10:00 »
My rear wheel alignment was slightly out in the R recently - it was causing the steering wheel to be slightly off centre when driving straight. Anyway, the VW dealers told me that the re-alignment process also meant that the ACC sensor had to be re-calibrated too. The equipment used to do this alignment is very expensive and some VW dealers don't even have it.
That's all fine and dandy when the car is under warranty... I dread to think what the maintenance of that sensor is likely to cost when these cars are a few years old and out of warranty.
