Author Topic: Golf R Front Pads & Discs Change  (Read 3934 times)
Offline eug2huge
« on: 11 April 2017, 17:21 »
Hi guys,
Does anyone know of any tutorials for changing the front brake pads and discs on the R?
Or can you tell me the torque setting please.
There's a 'Deutsche Auto Parts' video on youtube for a gti mk7. Is it the same procedure/settings?
Any help appreciated.
Offline gtiaps
Re: Golf R Front Pads & Discs Change
« Reply #1 on: 11 April 2017, 19:35 »
Hi guys,
Not had to do it myself on the Gti but done discs and pads before in loads of previous cars.
Once you've got the wheel off take off the metal clip that's holding the pads there should be 2 bolts at the back of the calliper top and bottom they are the sliders take them out calliper comes off.
Discs may have a pozi drive screw just holding disc in place take that out calliper off 15mins job apr each side.
Refit is opposite way to taking off....
Little tip unscrew brake fluid resovoir cap and wrap a cloth / rag around it this will make it easier to push the pistons back when fitting new pads.  :whistle:
Hope that helps..
2010 Candy White Scirocco 2.0 TDI
2016 Carbon Grey Gti 2.0 Fully Loaded
COLLECTED 29/4/2016 and well pleased with the GTI😆😆
Offline eug2huge
« Reply #2 on: 18 April 2017, 11:40 »
Thanks for the info.
any idea on the torque settings? that's what I'm really after.
Offline Bungleaio
« Reply #3 on: 18 April 2017, 12:21 »
Bolts that hold the disc to hub 8nm
Bolts that hold the brake carrier to hub 200nm
Bolts that hold the caliper to carrier 35nm but should be replaced as they are single use.
Abarth 595 Turismo + Classic Mini + Triumph Street Triple RS
Did have 3door DBP GTI PP
Offline eug2huge
« Reply #4 on: 18 April 2017, 12:48 »
Pow! Awesome, thanks dude.
Offline GeoBog
« Reply #5 on: 18 April 2017, 22:43 »
Here is the procedure, right from the repair manual.
https://uploadfiles.io/pkwip
2020 VW T-Cross SEL
2020 Renault Megane RS Trophy 300
2012 Fiat 500 Twinair
2007 Renault Megane 2
The two most important days in your life are the day you are born and the day you find out why.
Offline eug2huge
« Reply #6 on: 19 April 2017, 12:31 »
Thanks so much mate.  :smiley:
Offline eug2huge
« Reply #7 on: 24 April 2017, 10:28 »
Brakes fitted, nice and easy.
EBC USR discs with Yellowstuff pads.
