Author Topic: 1.8t aum pre cat lambda sensor. How do you get to it?!  (Read 2783 times)
Offline Carl!
Really stuck, all set for job just can't find a guide etc specific enough. Where about is it? What do i remove to actually see/get to it! All help much apprieciated!
Offline lemski
  • 16v
Re: 1.8t aum pre cat lambda sensor. How do you get to it?!
« Reply #1 on: 06 April 2017, 19:45 »
Jack up driverside from memory. Near the bulkhead under the turbo
Offline Carl!
« Reply #2 on: 07 April 2017, 08:48 »
So from underneath then? All videos ive found have gone from top but theyve always  been different model cars!  Cheers, will get it on my ramps weekend hopefully.
Offline lemski
  • 16v
« Reply #3 on: 07 April 2017, 12:41 »
I know you can get the 225bhp ko4 from the top. And probally the aum and other ko3 turbos aswell.
Looking at the downpipe id go underneather. Last one i did was in a mk2 golf and had to be done from through the drivers wheel arch. As soon as there cracked off they normally spin out pretty easy anyway.
Have you got a lambda socket or are you using a spanner
Offline Carl!
« Reply #4 on: 07 April 2017, 18:14 »
Ive got a spanner and was hoping for a bit of luck! As said first part is finding it! Thanks.
