Author Topic: Digital TPMS retrofit ?  (Read 4994 times)
Offline Sootchucker
« on: 31 March 2017, 07:46 »
Saw a video on Youtube last night of a guy that had retrofitted the full digital TPMS system to a new Seat Leon (same platform as the Golf). This is the system with sensors in the wheels that send a signal to a receiver that's then sent to the dash and you see on the dash center display as well as the headunit that actual tyre pressures in bar / PSI etc.
The system even has the ability to note tyre sizes, as well as if the car is fully laden or normally laden. Looks really cool.
Anyone know if this is doable on our cars and what's involved from a cost  / complexity point of view ?
Offline fredgroves
Re: Digital TPMS retrofit ?
« Reply #1 on: 31 March 2017, 09:19 »
The Leon has this as an option from what I can see.
Adding the sensors and enabling the display on the car is easy with some VCDS style tinkering.... But on a Golf how are you going to magically add a function and display from scratch on a computer system without it from the factory?
Basically, you can't.
Offline Gnasher
  • Formerly GnasherVXR
« Reply #2 on: 31 March 2017, 09:27 »
But was it designed to be on there and removed for cost reasons? It (apparently) was on some pre-production cars and I'd heard some other markets still get it?
I could be wrong though, it's been known.
2014 Golf GTI (PP) in Pure White with
Vienna Leather, Keyless Entry, High Beam Assist, Park Assist, Rear View Camera. Milltek Exhaust, Eibach Sportlines, 19" BBS SR wheels - SOLD!!!!!
2018 Audi TTRS in Nardo Grey with
Black pack, 20" Alloys, Privacy glass and Sports Exhaust. No mods yet!
Offline fredgroves
« Reply #3 on: 31 March 2017, 10:02 »
TPMS was the magical "sixth button" next to the gearstick... that never actually got used.
Offline JoeGTI
« Reply #4 on: 31 March 2017, 10:12 »
It's definitely possible.
http://forums.ross-tech.com/showthread.php?5328-TPMS-(Tire-Pressure-Meter-System-Direct)-for-VW-Golf-MKVII-MQB
kevinm might be along in a bit with more details  :wink:
Offline fredgroves
« Reply #5 on: 31 March 2017, 11:14 »
Wow
I wonder though if that will only work with early MIB1 units.
I can't see that they would carry the code over to MIB2/3? Unless it is common code used on vehicles that do use it.
Offline Talk-torque
« Reply #6 on: 31 March 2017, 11:22 »
Wow
US cars used to have a tyre valve system for TPMS. Not sure it was that sophisticated, though.
Roger.
Offline I wanted a GTi
« Reply #7 on: 31 March 2017, 21:13 »
Don't do it, I had TPMS on my CC and I spent so long trying to sort out the false readings from the spare wheel in the boot and the wheels on the car I turned it off with VCDS
Offline mcmaddy
« Reply #8 on: 31 March 2017, 22:18 »
Could be easily fitted but you'll need at least two control units fitted with cabling to ecu, new valves for wheels and then coding with vcds. Is it worth it as a retrofit? I'd say no when it's only a £150 ish factory option yet about 3 to 400 quid as a retrofit.
Offline kevinm
« Reply #9 on: 02 April 2017, 12:14 »
This is the newer single control module system used in most modern cars. Dont confuse it with the older tpms system with receivers in each wheel well. As the mk7 has the skinny spare wheel, you would only be fitting it to the 4 main wheels. The sensors only power on and transmit when they sense rotation so I dont understand how the guy above was having issues with the spare wheel sensor.
It's quite a cheap retrofit:
http://www.ebay.de/itm/VW-Passat-3G-B8-Golf-7-Steuergerat-RDK-Reifendruckkontrolle-5Q0907273-/352009794932?hash=item51f56b3574:g:OFEAAOSwjDZYgeEt
http://www.ebay.de/itm/NEU-4x-Original-VW-AUDI-RDK-Sensoren-5Q0907275B-/391739327940?hash=item5b357bc5c4:g:VyoAAOSwOgdY0uCk
You then need a loom made up. The trickiest part is the coding. I didnt retrofit it to my mk7 as I'm soon selling it but my next car will have it. I am currently fitting it to my caddy.
Current: His: 2020 M340i   Hers: 2019 GTD
Previous:
2014 GTI PP DSG
GTI ED30 DSG
