Author Topic: Active Info Display MPH to KMH conversion  (Read 7190 times)
Offline Fabio Bignose
« on: 25 March 2017, 08:23 »
Hi All,
Does anyone know or could hazard a guess as to whether the AID can be converted to KMH from MPH via a software change or is it an actual hardware swap?
I am hoping to get the go ahead to order a GTD Estate into Ireland as this model, among others not available here...  :sad:
Mk7.5 GTD. DCC, Keyless, Dynaudio, Tech pack, Alarm, Isaac Blue
Mk7 GTD. Xenons, 18", Climate Control, Keyless, Alarm, ( all optional in Ireland...! ) Dynaudio, DCC,
CSG.
Mk6 GTD. Alarm, CSG.
Offline gtiaps
Re: Active Info Display MPH to KMH conversion
« Reply #1 on: 25 March 2017, 09:13 »
I assume the swap on the display can be swapped to show kph through the settings on the head unit obviously your dials will have the mpg on the outer and kph on the inside  :whistle:
2010 Candy White Scirocco 2.0 TDI
2016 Carbon Grey Gti 2.0 Fully Loaded
COLLECTED 29/4/2016 and well pleased with the GTI😆😆
Offline I wanted a GTi
« Reply #2 on: 25 March 2017, 10:06 »
Surely VW were smart enough to code the display to show either kph or mph and not show both together? Although when you look at some of their ways of doing things like no keyless on a 3 door I may well be wrong.
Offline fredgroves
« Reply #3 on: 25 March 2017, 10:12 »
You see the unit of speed measurement in the MIB setup page just like you do on a Mk7 to show KMH between the clocks.
I don't think you can have a graphic for MPH and KMH at the same time though
Offline SRGTD
« Reply #4 on: 25 March 2017, 10:25 »
Active info display in the brochure for the mk7.5 Golf shows mph only in the speedometer, not both mph and kph;
http://www.volkswagen.co.uk/assets/common/pdf/brochures/golf-vii-pa-brochure.pdf
Non-UK models show kph only;
https://m.youtube.com/watch?v=MZjoZZGIP8Q
Gone but not forgotten;
2016 Polo GTI; Blue Silk
« Reply #5 on: 25 March 2017, 10:34 »
You would think producing just one set of dials and adapting to each market via software is a massive cost and manufacturing time saving..?
Whats frustrating is being able to see the perfect car for my current circumstances but being denied the ownership experience.
I even considered a Passat Estate in my desperation but 190hp variant not offered in Ireland...!!
I cannot go backwards in power so no logical progression from GTD Hatchback currently
There appears to be more doors closing on my VW relationship than opening currently...!!
Hopefully VW Ireland come good and go that extra mile for me..
« Last Edit: 25 March 2017, 10:39 by Fabio Bignose »
CSG.
Offline JoeGTI
« Reply #6 on: 25 March 2017, 11:50 »
I'd say it's a simple setting in the menus or via VCDS. I highly doubt there's any hardware difference.
Easy way to find out, call into a dealers that has a car with it fitted (even a Passat or Tiguan) and have a root through the radio settings. I bet there's a setting for mph/kph.
« Reply #7 on: 25 March 2017, 12:05 »
Good advice Joe.
I shall check this out if VW agree to import.
Thanks all.  :smiley:
CSG.
Offline mcmaddy
« Reply #8 on: 25 March 2017, 18:56 »
It used to be called alternative speed display or something like that on ore mqb cars. You should be able to toggle on the MFD between the two for when you drive abroad.
Offline fredgroves
« Reply #9 on: 26 March 2017, 12:15 »
I'll bet you just change the units of measurement in the car setup menu. As I said, it does it already...
