Author Topic: Help needed - passenger door - window, central locking and wing mirror  (Read 2639 times)
Offline SafferYork
Hi all.
My passenger door doesn't work - at all. The window does not wind down from passenger switch or drivers side switch. Central locking does not work at all on the door. And finally, I can't adjust the wing mirror from the control on the drivers door.
Oddly enough, when I remove the wiring loom from the door and put it back in again, the window works for about 5 minutes from the passenger door, and then nothing - does not work at all again, until I remove the loom and reattach it again.
I've pulled codes:
Address 46**** -------------------------------------------------------
** Controller: 1J0 959 799 AH
** Component: 4U Zentral-SG Komf. 0001
** Coding: 04097
** Shop #: WSC 31414
10 Faults Found:
01328 - Convenience System Data Bus
*********** 35-10 - - - Intermittent
01334 - Door Control Module: Rear Right (J398)
*********** 49-00 - No Communications
01333 - Door Control Module: Rear Left (J388)
01332 - Door Control Module: Passenger Side (J387)
01331 - Door Control Module: Driver Side (J386)
00931 - Locking Module for Central Locking: Rear Right (F223)
*********** 54-00 - Incorrectly Equipped
00930 - Locking Module for Central Locking: Rear Left (F222)
00928 - Locking Module for Central Locking: Front Driver Side (F220)
*********** 27-10 - Implausible Signal - Intermittent
These codes are telling me that nothing is communicating! The rear doors lock and unlock as they should, and the windows do (intermittently) work....
Please all - help is seriously needed. Going mad!
Offline itavaltalainen
I would look at ccm itself!
